south bend clutch
Hey i have a 2004 with the HO and six speed. I sled pull may be five times a year. I found a south bend dd clutch, but it is a ductal flywheel. It saya it is rated for 650 hp and 1300 ft lbs but it is not SFI approved. Do you guys think it will hold up to sled pullin a little. I dont do it alot. An SFI approved clutch is like $1700- 2000. I can get this one for $1200. Please let me know thanks.
No it will NOT hold up to sled pulling, Do not pull sleds with a flywheel that is not certified.
What exactly are the differences between the sfi and non-sfi approved?The 3250 is the only non sfi,correct?
No the ductile clutch comes in the 3600 flavor as well. The difference is simply that the fly wheel is not rated for competition by SFI and should not be used in that manner. It is a lighter weight flywheel and not designed to withstand the abuse of sled pulling.
(Post 2338810)
ok guys thanks
Go over to CompD Kevin Cole aka (Twistedgoat) has a haisley street puller for sale for 1200. They will hold everybit of 650hp. Brother has over 30 hooks on his and only had to adjust it and he daily drives the truck every day. If you need a link to the thread pm me.
