smoke switch trouble
Old Apr 12, 2009 | 07:09 PM
dirtracer1880's Avatar
i tapped into the 5 volt reference wire and the signal wire on the factory harness side. when i turn on the switch the cel came on for p0238 map sensor voltage too high. does anyone know what i might have done wrong. do i need to add a resistor like in a lockup switch
Old Apr 12, 2009 | 07:41 PM
ihatesparkplugs's Avatar
throw a 10 om resistor in there and you should be fine. I t will cost you a whopping $1.99 at Radio Shack, and if I remember right you get two of them in a pack. Any trouble let me know
Old Apr 12, 2009 | 07:54 PM
i will try that thanks for your help
Old Apr 12, 2009 | 08:25 PM
not a problem bud. If you need I can send you a very helpful set of pictures and complete instuctions, just to check yourself. A guy here on the forum sent it to me. Just shoot me your email via pm if you want it.
ridlangus123
Dec 30, 2013 08:36 PM
Ditchhand#2
Dec 6, 2013 02:19 PM
thegoat86
Oct 29, 2008 05:23 PM
DODGE 92
May 13, 2005 01:38 AM
redramnc
Mar 28, 2005 06:58 AM
