Smoke...Smarty
Smoke...Smarty
This post is not about how to make mucho smoke, The 06 in my sig has enough, even with the flux 4's alone, what i need to know is how to adjust the settings for the least LOW END smoke possible!
i tried SW1 and TQ1 timing:0(Default) still get quiete a big cloud of smoke till turbos spool, unless im really really easy on the pedal.. it actually gets so much fuel its faster on spool up with less throttle then at full throttle.
BTW can anyone tell me what the torque management difference is between 1 - 4?
All i know i need to set limited shift to off, to be able to make boosted launches, which means no back up lights and no gear indicator in the dash
can someone explain the timing differences to me please? and if i leave it on default, what number is it set on?
And what timing should be used when injecting either water/meth or Nitrous?
stock03
34
Apr 21, 2011 07:40 AM
Ghost Ram
Feb 2, 2008 07:50 AM
