Smarty Upgrades??
Old Nov 30, 2007 | 10:44 PM
ariz5247's Avatar
Smarty Upgrades??
I purchased my smarty earlier this year. Probably around June 2007. Are the new downloads that I need to worry about or am I in the clear? (my truck is a 2006 CTD)
Thanks!
Old Dec 1, 2007 | 08:14 AM
MikeyB's Avatar
It's up to you. The newer versions has latest DC updates and maybe a little more refined. But if your happy with the current version stay with it.
MikeyB
Old Dec 1, 2007 | 01:33 PM
ariz5247's Avatar
I guess I was more concerned that the dealer may now be able to tell that I have used a programmer when I take it in. I read something about new codes from the factory? Does this mean that when I set my truck back to stock when I take it in for service there will be an obviouse tell that a programmer has been used?
For example:
I set my truck back to stock and take it in for servicing. Then Mr dealer updates the truck with newer software. I then use my smarty and set back to stock (with old factory settings programmed from the Smarty) for the next service job.
I probably made that as clear as mud!
Old Dec 1, 2007 | 04:24 PM
wingrider's Avatar
If I'm not mistaken, when you go back to stock on your truck, take it in for an update at the dealer, and then go and reload your Smarty, it will take the newest version and lock it in the Smarty.
As far as I know, Smarty does not save any stock settings in it...once you put your truck back to stock the Smarty is no longer VIN locked.
Hope that helps.
Old Dec 1, 2007 | 04:39 PM
jgiachino's Avatar
When DC comes out with a new reflash, so does Smarty (based off of the new reflash)....once you're on version x of a flash (smarty or dc), you can't go backward with either one....so no worries.
MTC
Nov 30, 2009 05:50 PM
silkywoods
Feb 6, 2008 06:45 PM
barryp
Sep 26, 2007 09:18 AM
cumin@you
Sep 20, 2007 10:02 PM
abc4yew
Oct 4, 2006 11:39 PM
