smarty stacked?
Old Jun 6, 2007 | 05:16 PM
Ramtuff06's Avatar
smarty stacked?
What are the benifits of stacking?
and what would be good to stack with a smarty beta 4.4 program?
Thanks
justin
Old Jun 6, 2007 | 05:20 PM
dodgezilla04's Avatar
well justin. since the smarty 4.4 adds pressure, you'll want to steer clear of a module that also adds pressure.
if you run smarty on odd numbered programs, you will need to use a module that doesnt do timing too. know where i am heading? 2 components cant add pressure and fuel or you will have too much of either and bad things will happen.
that being said. i did stack my quad race with 4.2 and OMG. it was really fun, but probably not the best idea. i only did it for a mile.
Old Jun 6, 2007 | 05:28 PM
Ramtuff06's Avatar
Thanks for the info dodgezilla04
I was thinking of a tst box or something similar
my friend has one and he swears by it
another ? what is the difference between the beta 4.4 and 4.2
Old Jun 6, 2007 | 05:56 PM
tritont's Avatar
you'll have to be real careful with the TST. It's an extreme pressure adder. I'm running the Smarty 4.3 and if I run the TST anything over 2/0 bad things happen !
You will definitely need more fuel and a way to get rid of the heat if you're gonna try stacking.
Not sure about a beta 4.2 but, the 4.4 is for towing and mileage and not so much performance.
Old Jun 6, 2007 | 06:02 PM
wap's Avatar
wap
tritont, the tst only add pressure if you want it too, I have mine turned off so can put it on level 9/9 and still no pressure.
Also, just cause its for fuel milage and towing doesn mean that there isnt much performance, I am gonna have to strongly disagree. Not trying to argue on either point just stateing the facts.
Take a look at what I think of my smarty stacked with my tst on the thread I started today.
Old Jun 6, 2007 | 06:12 PM
tritont's Avatar
I was only relaying what Bob told me about the 4.4. I asked if I should use the 4.4 and he said to just stay with the 4.3 cause the 4.4 was written for better towing and mileage
That is true about the TST.... but, I don't even have my RP connected. It doesn't work on the 6/6 and later Cummins. I do leave the timing on auto though.
bridleman
Apr 24, 2007 12:49 AM
srt20
Mar 18, 2007 07:27 PM
973604x4
29
Oct 11, 2006 01:54 PM
Tiger Rag
18
Mar 9, 2006 11:11 AM
