Smarty Stack
Old Feb 17, 2008 | 03:21 PM
Torque master's Avatar
Smarty Stack
Can a Smarty Stack Well With Hot Juice" And an Edge-EZ ?
Old Feb 17, 2008 | 03:25 PM
tristan21's Avatar
The EZ is fine but the juice will be pointless.
Old Apr 8, 2008 | 06:58 PM
1slo_MM's Avatar
i have the same combo hot juice/ez and was wondering if adding the smarty would be a bad idea??
Old Apr 8, 2008 | 07:07 PM
Not Sure if it's would be a good idea to Run the Smarty on Top of the Juice/ EZ , Are you Running the Hot version of the Juice?
If you were to do it, Id Run the Juice on -0- Just for Gauges , And Run the Smarty / EZ.
Old Apr 8, 2008 | 07:15 PM
matego's Avatar
madhat's monkey boy...
You are 100% correct. Leave the juice on 0 and use it for gauges. You might want to search Omaharam becuase he was trying stuff like Smarty 4 Edge 3-4 etc. to see how they stacked. Personally, I had all 3 and I used the Edge for gauges for a couple months and then decided it was pointless having the Edge.
They are great boxes but once you run a Smarty and see how smooth the power delivery is you dont need adjustable settings. Thats what the throttle pedal is for.
Old Apr 8, 2008 | 07:44 PM
I never tried the Smarty so I can not comment on it , one way or another, Although have have herd more positive than negative comments.
I had Planned to go with the Smarty here shortly but have decided to sell my Truck , and have a buyer. Going With a )07- Tundra 5.7Litre Center Shifter, all black,, sports packedge, 2-wd Regular cab shortbed going for the Sports Truck Feel /Ride, Diesel has Just Hit $4.50 a Galon here on the Big Island of Hawaii (Ouch! )and I can get Regular unleaded for the Tundra 18--19 MPG Not too bad here for 3.60 per Gal. Tundra-381-HP Stock , TRD Supercharger Available Summer of -08 , Turns the Tundra into 500-HP Truck.
Never the Torque and HP of the Cummings Though, I scored it on E-bay for Such a Deal only 681- Miles on it.
Anyhow Back to the Point , Are you Running A Built Transmission. If so you can comfortably leave it in the Hot Setting for Daily Driving Hot Juice on #5 Hot" Stacked---with the EZ on #2 , I leave my Truck on these settings all the Time with No EGT Issue's , I Will see engine Temp's Hit 210% up-a steep Grade with an un-loaded Truck. I am also referring For Daily Driving Un-loaded Non High Hill Grade areas. Try Driving in someones Truck that already has the smarty and see if your really impressed with it, if possible, I do not think the difference will be extreme enough to justify the change, If you had only the Juice id say " go for it" since you have pressure -EZ I don't know if you will notice A lot more than a Hot Juice Stacked with Edge -EZ , and save yourself 650.00 Bucks.
Old Apr 8, 2008 | 07:57 PM
matego's Avatar
I was looking for every excuse to keep my Edge because of the on-the-fly adjustability but once you run the Smarty with a aftermarket turbo the top end is amazing. The Edge stops agressivly fueling at 2700 and the Smarty will allow 3500+
Old Apr 8, 2008 | 09:38 PM
1slo_MM's Avatar
ya i was worried about that kind of answer.. ill just keep the HOT Juice/ EZ i have for now then.. thanks
-dru
Topper
Mar 3, 2008 10:17 AM
white250005
Oct 25, 2007 10:19 PM
smoky beast
Oct 18, 2006 06:58 AM
B.Law
16
Apr 22, 2005 02:28 PM
Cat Cracker
Jul 14, 2003 12:17 PM
