SMARTY-not impressed-suggestions?
Old Feb 20, 2007 | 11:24 AM
omaharam's Avatar
Originally Posted by ramtd02
Agreed, My smarty with Wild#9 will easily get my SPS into the 50 psi range, so something in your drivetrain may be letting go, and not causing the engine too reach full load!! I cant make any comparisons, but from what i understand the Aurora 3000 is a similar setup to the SPS6280.
I don't agree with your guy's assesment, but I will load a mild tq mngmnt program just in case. I'm pretty sure I'd know if the tranny was slipping. i've been around performance cars long enough to know the signs. The rpms stayed in check with my rate of acceleration. The shifts were firm and on time. And for boost, your SPS is wastegated, so you can set it to build 50psi. The Aurora isn't. It depends completely on how much fuel you feed it to determine the boost level.
I'd be curious if anyone has dynoed with just a SMARTY or SMARTY with a pressure box to see what hp figures were there. Right now, I'm guessing I'm getting 425ish to the ground vs 500 with the Juice.
Old Feb 20, 2007 | 11:51 AM
ramtd02's Avatar
I am dynoing on thursday (DJ and Mustang,) with the smarty, and then with the smarty and DR.P
The dynos i have seen thus far were 450-470 with "just" the smarty, and one feller was 505 with smarty, and a quad product.
Old Feb 20, 2007 | 11:57 AM
omaharam's Avatar
So SMARTY and mp-8 or xzt should be making similar power to my HOT Juice and mp-8 or xzt. As advertised it should, but if those are numbers people are actually getting, then it really should. So something is wrong. Guess I'll just try a few different programs. I wish they didn't take 30 minutes to download.
Old Feb 20, 2007 | 11:58 AM
BigBlue's Avatar
TexasCTD on a stock auto with stock fuel system and turbo, exhaust, and intake, did 466hp and I wanna say 900 or a 1000tq with smarty on #9. Not sure which program he was running though. I think just the standard one that comes with the smarty when you buy it.
Old Feb 20, 2007 | 12:21 PM
MikeyB's Avatar
I believe TexasCTD is using the earlier 307D202B program.
Think his numbers was around 467hp and 922tq.
MikeyB
Old Feb 20, 2007 | 12:30 PM
973604x4's Avatar
I experienced the exact same thing as you. Hot Juice/MP8 much better than Smarty/MP8. everything you have said about the smarty on your truck is VERY similar to how it acted on my truck. Not bashing the Smarty at all cause is certainly has some features that lots of other companies will never produce....but it just wasn't the ticket for me on my truck.
Old Feb 20, 2007 | 01:16 PM
omaharam's Avatar
Which programs or programs did you try?
Old Feb 20, 2007 | 01:28 PM
973604x4's Avatar
several.
very first program to hit US soil.....8/19/06 is when i tried that http://dodgetruckworld.tenmagazines....os=1&id=224113
modified torque management....10/06 was when i did that
stock torque management....also in 10/06
wild thing torque management....couple weeks ago
i included the date to help determine exactly what program i was running.
like i said omaharam, i had very similar results to you.
Old Feb 20, 2007 | 01:48 PM
omaharam's Avatar
several.
but what about the different programs like stock turbo/aftermarket injectors or aftermarket turbo/stock injectors or aftermarket both. You can do all those with any tq mngmnt level.
Old Feb 20, 2007 | 01:53 PM
973604x4's Avatar
notice the date.....those options were not available for the first 3 programs i tried.
wild thing was....i dunno. it belongs to another member here, let me PM him.
Old Feb 20, 2007 | 02:15 PM
973604x4's Avatar
wild torque management was aftermarket turbo / aftermarket injectors
Old Feb 20, 2007 | 02:21 PM
omaharam's Avatar
Bummer Dude!
Old Feb 20, 2007 | 08:29 PM
omaharam's Avatar
Ok downloaded the aftermarket turbo/injector program. It was better. Felt a lot better in 1st and 2nd but then faded in 3rd and 4th is still no comparison to the Juice. It picked up 3 tenths from the program for stock injectors. But at this point I am going to go a different route.
Old Feb 21, 2007 | 01:54 AM
TexasCTD's Avatar
MikeyB
You got my curiosity up, so I went out and hooked up my Smarty to see what version I had. IT is the 303D202 version. I haven't updated since I got it in Late September/Early October.
While I had it out, I decided to try SW 8 just to see what the difference is, if I can tell it...without added timing. I have only run it on odd numbers so far.
Old Feb 21, 2007 | 07:14 AM
MikeyB's Avatar
TexasCTD,
My bad, thought you had the 307 program.
I can say that the 307 has more spunk than the new 309. But I do like the lower EGTs that the 309 brings.
With the 307 I could easily hit 1300 degrees on a WOT run, 309 is 1100 degrees. Both set at level 5.
BTW, love the Colt 45D video...
MikeyB
