Smarty Moderate Torque Update
I was was wondering what the moderate torque update changes. dose it actually make more power or just change stuff around. and what is tourqe management really? what kind of power does it make over stock smarty settings and while on the subject how about the wild thing setting?
heavier fueling down low and less defueling between shifts. top end, no real difference.
Fill out your sig so we can see what you have... if you have a stock tranny, you don't want to mess with mod or wild TM anyway.
What TM does is regulate the amount of defuel between shifts and initial fueling from a dead stop... mod lessens the defuel, wild lessens it even more... making for a very sensitive throttle... and hard on your tranny. A built tranny can take it... a stock one cannot. |
My Sig
im gonna get to you sig i gotta take a pic of my truck, i just had a suncoast converter, valve body, and flywheel installed.
Here is my Sig
I have a similar question regarding Smarty downloads. Is there any material difference on an '06 whether you run the softwares designated for years '03 through '06 as opposed to '04 through '07? Both softwares apparently work on an '06, but do they provide identical, equivalent performance? Bob? Marco?
Does the update make more power or does it change the responce?
I asked the same question. both programs are the same one for 03 has more info to download but both are the same power wise.
