smarty jr and emission testing
The PoD won't detune anything as far as emissions is concerned. It takes x fuel to run the rpms that the emissions tester wants.
The best way to pass is to go back to stock, you 'should' be fine without a cat.
If your state has the opacity test I think the POD would be beneficial (especially if you have aftermarket injectors) by setting the Jr to SW1 stock timing, stock tq, and POD 0. What are your thoughts ?
PoD reduces output by reducing the effective throttle positoin. So PoD 99 allows 100% of TPS input .PoD 0 allows 0% TPS input, your truck would only idle.
My 06 will still drive up to about 15 mph when set to 0 and will not smoke. I have not tried revving while in neutral but I figure if it will pull itself 15mph and nothing more it should rev sufficiently and not smoke at all for a snap test. I will try POD 0 again tomorrow and report back.
2500Ram
Apr 15, 2010 12:18 AM
