Smarty error downloading...
Old May 8, 2008 | 05:59 PM
moparman13045's Avatar
For some reason I am having a problem downloading the new REVO program to my S-04 I am getting error message "Error on Smarty0 FTD2XX.DLL not found" , anyone else have this and whats up? Thanks
Old May 8, 2008 | 06:30 PM
Rick D's Avatar
I'm having an S04 problem also, " unable to connect smarty or software not compatible" I've reloaded drivers, and tried the newer Smarty USB.
I've done this many times and never had a problem until now.
Rick
Bob Wagner's Avatar
you need to unzip and install the driver
Hello , To be able to update your smarty ecm tuner. Please follow these guidelines.
Start by right clicking on your desktop to create a new folder. Rename the new folder smarty.
You will need to download the driver to the smarty folder. Save the driver to the smarty folder http://www.madselectronics.com/downl...DM_2.00.00.zip
You will need the smarty usb.exe This program allows you to update the smarty. Save this to the smart folder http://www.madselectronics.com/downl.../SmartyUSB.exe
The driver and the software programs need to be extracted into the smarty folder using THIS extraction tool. http://prdownloads.sourceforge.net/s...2.exe?download
Here are the directions for installing the driver http://www.madselectronics.com/downl...stallation.pdf
Once you have the driver installed you can use the smarty usb.exe program to update the smarty software. Click on the smarty icon. Press run. You will now see a seen button. Before you hit the send button you need to load a program into the smarty usb.exe. Click on file. Open , look in the smarty folder to find the smte file to load into your smarty.
Load the file and press run. It will take about 40 minutes to update your smarty.
Thanks
Bob
Old May 8, 2008 | 06:31 PM
Bob Wagner's Avatar
Originally Posted by Rick D
I'm having an S04 problem also, " unable to connect to smarty or software not compatible" I've reloaded drivers, and tried the newer Smarty USB.
Rick
which error is it? 2 different causes
Old May 8, 2008 | 06:32 PM
06RAM2500's Avatar
Happen to download the driver?
Old May 8, 2008 | 06:49 PM
Rick D's Avatar
Bob, that the whole message that i get.
The first time i plug Smarty into the usb it lights up normaly with version # ect.
then when i try to download i get the obove message and the smarty screen goes to all blocks on the top line, then i have to let it sit for a couple of hours and the readout comes back.
Rick
Old May 8, 2008 | 06:55 PM
Bob Wagner's Avatar
if you would like to send it in I will take a look at it and fix ya up
Old May 8, 2008 | 07:08 PM
Rick D's Avatar
Thanks bob, could you PM me your mailing address.
Rick
#2 only
Sep 4, 2008 02:02 PM
GOT BOOST?
Apr 7, 2008 03:10 PM
JRAPTOR04
Feb 14, 2008 02:32 AM
Merritt
Dec 9, 2007 10:05 PM
Kevin Krieger
May 10, 2007 10:35 PM
