Smarty Boost numbers
Looking for the boost to expect with my smarty... I have the edge in still but just the pyro hooked up, i was wondering if i could hook the boost and the data connection up to us it as gauges and undo them if i had to unload and reload... (no injector crap hooked up)
Looking for the limit the edge will read (32psi?) and if the smarty will peg it...
May go to gauges but i want pillar and dont want to lose my grab bar.
Not too sure what # the EDGE will read to, but the SAMRTY even on low levels will put you over 36psi. If the EDGE does not do boost fooling then you might want a Boost Fooler so you dont throw a overboost code.....
When I was running SW#3-#5 I could hit 38-42 psi easily
sCreamin400
Nov 2, 2008 01:46 PM
vwjunkie53
19
Nov 9, 2007 02:27 PM
06 smoker
Nov 11, 2006 02:35 AM
hellotbone
15
Mar 31, 2003 06:49 AM
