Smarty
Old Apr 21, 2007 | 01:21 AM
Huntsalot's Avatar
Smarty
Hi all I have an 07 mega cab with the 5.9 I am running level 2 with the added timing smarty and I towed my keystone raptor today unloaded and was seeing high egt like 1400 barley going see like 1200 all day not towing whats the deal?????
Old Apr 21, 2007 | 01:35 AM
MegaBOMB's Avatar
Even numbers on the SmartyCR don't have any additional timing, you'll want to use an odd number to get the benefits of additional timing.
Old Apr 21, 2007 | 10:48 AM
ShutupAndHoldOn's Avatar
I tow a Raptor 3612ds. I tow with my Smarty on 3 and EGTs are pretty good. My EGTs are post turbo but the highest I see is about 900. That is climbing with overdrive. As soon as I switch OD off my EGTs drop to 750ish.
You may want to download the latest version of the Smarty software and check your settings try running switch 1 or 3 (30hp or 60hp with timing) I'm not sure what level 2 with timing means.
Old Apr 21, 2007 | 12:20 PM
Luvnacumns's Avatar
WOW I tow with #7 and the mp-8 on 40% and have only hit 1300 degrees!
Here's a couple of pic's
Old Apr 21, 2007 | 01:15 PM
jgiachino's Avatar
You need to use level 1 or level 3 (or any odd # software) to get additional timing.....
Level 2 (or any even # software) = more fuel, no additional timing = higher egt's....meant to be used with another method that adds timing...
Old Apr 25, 2007 | 12:33 PM
Huntsalot's Avatar
Hey just plugged my smatry inn to change levels and I was on level 1. I think there is something wrong my egt are way to high. I am going back to stock for now. any input I have an exhaust and an s&b intake.
Old Apr 25, 2007 | 03:35 PM
jgarrett's Avatar
i dont think you are supposed to tow on level 1
Old Apr 25, 2007 | 03:52 PM
tcr's Avatar
tcr
I tow on 1,3 and 5 all the time. No problems.
Old Apr 25, 2007 | 03:53 PM
jwb600's Avatar
i run mine on level 9 and it gets hot but only when you get towards overdrive
Old Apr 25, 2007 | 03:56 PM
jgarrett's Avatar
Software number One,
The Fuel Saver software. Mpg gains vary, in most cases a + 2Mpg has been reported. Please note that the timing in this software is rather aggressive.
HEAVY TOWING is not recommended with this software.
Old Apr 25, 2007 | 04:10 PM
The setting for fuel saver are not available for the 06-07 version. For Huntsalot's year switch 1 is +30 with timing and switch 3 is +60 with timing.
Old Apr 25, 2007 | 07:31 PM
pupeperson's Avatar
Bob Wagner posted somewhere (either here on on TDR) that towing w/ Smarty on 1 on was ok on CR engines. Not ok for earlier models.
Old Apr 25, 2007 | 07:35 PM
rustyshakelford's Avatar
Shane-
you still need some airbags!!
#1 fuel saver is for second gens i think. huntsalot-listen to everyone here and tow on an odd number. 3 or 5 and report your egst, they will be alot lower
brett
Old Apr 25, 2007 | 09:41 PM
tcr's Avatar
tcr
Where did you get this info?
Old Apr 26, 2007 | 12:37 AM
jwb600's Avatar
ive towed a trailer on sw9 and I had no issues at all. I didnt try to see how hot my egts would get either. I have a tandem axle car trailer and it pulls that like its not there at all. I wouldnt do this with a stock transmission. I think it would destroy it.
