single stack kit
Old Dec 5, 2008 | 06:25 PM
dodge_24's Avatar
single stack kit
need help where is everybody getting the single stack kits
and how hard is it to install
i found one kit for 147.00 tried to call them to get more info and didn't get an answer
will the 4" kit have everything to install and add a 6 inch stack
thanks
Old Dec 6, 2008 | 02:51 AM
mpracehemi's Avatar
In the search (above) type in 'stacks', plenty of reading and how to... Also there is 'chromeroom'- blackclouddiesel-
I just googled stacks and found some too. I pieced mine together from a couple diff. places. I got my 5'' stack off ebay, elbows came from local truck shop.
If you have a drill, hole cutter, hack-saw/sawlsaw, it's not that dificult to install.
I'm not sure if the 6'' necks down to 4''.
Old Dec 6, 2008 | 07:04 AM
homewrecker's Avatar
Any local big rig shop should have all you need or as mentioned above,the chromeroom or Chrome depot.All you need is a 12" piece of flex,a 90* bend 4" pipe, a 4" to ?" coupler to match up with the stack you you choose.You should be able to buy everything but the stack for under a $100.If you call the chrome depot they can hook you up with everything.A couple of the employees there have Dodges with stacks so they will know exactly what to get.
Old Dec 6, 2008 | 10:37 AM
SMOKIN-U's Avatar
i made my own it was pretty simple really 5" downpipe about $130 5' of 5" $5 a foot. A couple feet of flex pipe a 5" 90* elbow i think i used 3, 5-5 couplers and i made the stack out of 38" of 7" exhaust pipe all together i have less than $300 in it from the turbo back
nasty01cummims
Jun 29, 2009 09:59 PM
DIESELWRKS
17
Jun 16, 2009 09:15 AM
53 willys
80
Oct 3, 2008 09:50 PM
greyrig05
Dec 18, 2006 06:53 PM
SilverHoss99
Feb 15, 2006 05:59 PM
