Scary Larry??
Loaded the 2.4.C - Not sure about it!
The program seems to have some issues rolling into it, say from a cruising speed to hard acceleration, it begins to pop and miss and the turbo gauge jumps all around like the rail is being drained, but rail gauge says it fine… strange. Has anyone had the same issues? As you can see, I am running a silver bullet and have not had this type of issue with the old CL even stacked with the TST running at 650 H.P. Any insight would be appreciated. By the way, this occurred with the BD by itself, not stacked.
Thanks,
Thanks,
I am having issues with 2.4.C also. At full throttle it seems to run good. But at part throttle rolling into it, the engine surges and shudders like it doesn't have enough fuel or something. I tried a 1/4 mile run using my Outlook monitor to measure 0-60 and 1/4 mile times. My 0 - 60 was 5.5 sec and my 1/4 mile time was 12.75 sec
. I'm sure the 1/4 mile time was way off. I would guess mid 13's. It was pulling very hard though all the way through and I was using meth injection and boost fooler.
The only way I think might work is to restore your truck to stock and then put the regular program v 2.4.0 (non-crazy larry) on your triple dog using UPDATE. Then delete all copies of the beta version from your computer. Then download crazy larry v. 2.3.8 onto your triple dog.
I guess I'm the odd one, I have had no problems with 2.4c in fact the low end is incredible. Last night at the track fully preped with vht, 37 inch tires I'm running and stock 3.73 gears I went sideways. Had to get out of the gas to regain tracksion. I can't wait for the scarry larry version!
Nice Thunder, do you have an upgraded turbo?
On my truck, 2.4.C is working better than B in the shuddering department- only getting a little under mild accelleration at about 2K RPM instead of 1500-2000.
I'm really anxious to get a new turbo popped in and get the pressure added to this program. Other than the slight shudder, its great.
