Rate this setup, what should I tell him to improve on next?
Friend has a 03 dually, not sure if S.O. or H.O.
SB dual disk clutch
Air dog
TST Powermax
80 hp injectors.
Stock Turbo (told him to go HTT)
AFe intake, Straight pipe.
I advised next a vulcan straw, big line supply kit from glacier, modified or dual cp3, turbo, input shaft, or studs/twins next,
I tried to convince him Smarty was better, what do you guys think of TST stuff?.
He *thinks* to have 550HP, which i don't agree with, hes adding the "claimed" advertised numbers in his head. I said a dyno will only prove that not in your head stuff.
I'm thinking 450-475, especially on stock turbo?
So what do you guys think I should tell him, seems money isn't an issue for him, must be nice.
SB dual disk clutch
Air dog
TST Powermax
80 hp injectors.
With that stock he341, he is maybe closer to 400 than anything... Now if he had a proper turbo, that setup might be closer to high 500's. That stock turbo will not support much , and I am certain he is overspinning it way outside its map. Turbo before anything else.
The TST is great too but it is so much better when stacked with a pressure box and/or a programmer. I agree that he is probably not where he thinks he is if he still has the stock turbo too.
YounanDiesel
Oct 27, 2011 09:00 PM
Joe T
20
May 2, 2007 07:22 PM
