Quadzilla RPG3000
Old Jul 4, 2007 | 08:36 AM
PowerDually's Avatar
Quadzilla RPG3000
I just got one of these and this the question.
I am running a pressure and it is plugged into the rail sensor. THe gauge connection connects here also.
So what plugs in first?
I can figure that the gauge should go first but just want to make sure.
thanks
Old Jul 4, 2007 | 08:41 AM
rich2500's Avatar
you are correct guage first
Old Jul 4, 2007 | 09:52 AM
thanks for the info.
Old Jul 4, 2007 | 10:23 AM
shortbed rv's Avatar
On my Commander the rail pressure is a T-tap. The Tap is tapped into the XZT harness at the fuel senor. The stock plug then plugs into the XZT harness.
http://www.quadzillapower.com/downlo...on_install.pdf
Instruction:
good luck
Old Jul 4, 2007 | 10:25 AM
vzdude's Avatar
DTR's 'Go to Guy'
RPG is different I guess.
mopar440cu
Nov 21, 2015 08:39 PM
norcaljr
13
Aug 5, 2008 10:13 AM
Smokin98.5
0
May 29, 2008 05:35 PM
FireNhole
14
Feb 6, 2003 07:29 PM
