Quadzilla commander data logs
Old Aug 11, 2006 | 04:32 PM
dieselengineer's Avatar
Qzilla
Is there anyway to connect the commander so when you just shutdown the engine you can still read the data. I would like to check the max and min readings, however you need to keep the engine running. If I forget to check before I shutdown the engine I lost the values. Is there a way to retreve them after the unit is powered down? Or is there a way to keep the power on like the lights stay on for a few minutes after shutdown?
jj3500
Jan 12, 2009 11:42 PM
norcaljr
13
Aug 5, 2008 10:13 AM
CalypsoCowboy
Jun 1, 2007 03:53 PM
stock03
Nov 9, 2006 11:27 PM
Cisco
Aug 17, 2006 09:24 PM
