Quad Boost Fooler?
I the quad boost fooler worth the money if so what does it mean by modifing the waste gate on my 2004?
The '03 and '04 turbos have a boost elbow going to the wastegate. With a modified or adjustable boost elbow will allow the boost to go higher. The boost fooler will prevent the ECM from defueling because of the higher boost being read by the MAP sensor.
MikeyB |
How do you modify or where do you get and adjustable? Thanks
Available on ebay, TST and I think Quadzilla.
MikeyB |
I found tons of boost fooler, but no elbows. Do you like it.
Here's one on TST website. http://www.tstproducts.com/index.asp...PROD&ProdID=33
With the adjustable elbow my boost went from 22psi to 32psi. MikeyB |
its worth it! more boost and cooler EGT's, plus it pulls harder!
so I can buy an elbow and fooler and get more power for little money ??
Originally Posted by expressfish
(Post 1439213)
Quad's boxes do not come with boost elbows. In fact, Quad told me that they actually saw a decrease in power on the dyno while running a boost elbow. My 03 saw the same boost with or without it when I was running the Quad box....
When I was running the Edge EZ I saw some gains... |
(Post 1439224)
answers my questions , thanks. dont want to loose any power :) just thought I might get alittle more w/. an elbow.
