Pyro sender before or after turbo?
Has anyone or does anyone know of a person who broke or caused damge to turbo and/or engine because they were "trusting" there gauge/monitor??
Seems common sense that someone would back out of the throttle if they temp. got to 85%-90% of max temp. regardless of actual temp.
I use my gauge to look at as an overall measure of exhaust gas. Not as an
"I can run my truck up to this temp. before I back off" gauge.
Just my .02$
Just my .02$
Just my .02$
Just my .02$
Which is harder on your engine... Towing up a mountain at 1350 for 10 min. or dragracing and hitting 1600 in the last 1/8 for 5 seconds?
Just my .02$
Just my .02$
Why have the guage if you dont want an acurate reading?
six of one half dozen of the other.
Pre-turbo, it's not that hard. Go to Harbor Freight get the chinese tap and die set. I did the running engine while drilling thing, but do what you want. To me it seemed pre-turbo was better, but anything is better than nothing.
They sell manifolds that have 6 already drilled holes (I think aviation do or can have multiple EGT gauges)
http://www.hellmannperformance.com/1...20manifold.jpg
Hellmans makes good stuff from what I hear.
If I had to do it all over agian, I would stay post turbo. Less headaches with installation and if you ever need to make your truck appear stock, it will be easier. The few second delay you have does not matter unless you stare at your EGT the whole time anyway. Sure you can set your Edge to defuel, but set it to 1000 or 1100 and you will still be safe.
mine to. but isnt it all true about c-15, 3406, 3176, 3208, series 50,series 60, 6v92, 6v 72, mack aset 460, n14, isx. They all seem to be bigger and more powerful than a 5.9 cummins and their pyro is after turbo
they are post turbo incase of the probe ever breaks off, it wont go through the turbo. but that is VERY rare and not likely to happen.
if you want to monitor your cylinder temps, mount it pre turbo. if you want to monitor your turbo temps, mount it post turbo. otherwise dont bother installing one because it wont do you much good if its not monitoring exactly what you want to see.
