Pyro question
Old Sep 3, 2007 | 05:25 PM
Seeder's Avatar
Pyro question
When I first bought my 06 I had a local shop install a pyro, boost and trans temp gauges for me but when he installed the pyro he installed it post turbo. At the time I figured it would not be bad since the truck is stock and planned on keeping it that way.
Now I have ordered a Quad XZT with the commander and was wondering if the pyro should be mounted up on the manifold or will the post turbo be ok? I know that there is a temp difference between post and pre tubo but not sure what it is roughly (200 deg?).
Also wondering if I should keep the analog gauges and use the commander as well and compare the two set-ups for accuracy or if I should s-can the gauges all together?
Any info will be appreciated.
-Jeremy
Old Sep 3, 2007 | 05:28 PM
Luvnacumns's Avatar
-Jeremy
Keep them all.. You will be surprised in the difference... I would drill the commander pre turbo then you can set it to de-fuel if she gets too warm!!
alltimelow1
Mar 6, 2005 02:49 PM
big pappa
Feb 27, 2005 10:00 PM
lovemysan
Jan 12, 2005 05:19 PM
rjordan
May 4, 2004 01:55 AM
CTD99
May 19, 2003 10:24 AM
