Put your CR Pressure Relief Valves back in!
So that's why I have never cracked an injector... I left well enough alone... I had considered it several time when I had my Smarty TNT-R; any additional rail pressure adjustment (via the Smarty) would set of a "Rail Pressure to high" code. Seemed very annoying at the time and I even considered a block off or plug solution. Through my cheapness (retrospective wisdom in this case) I decided to just back the rail pressure setting back to normal (although increased I'm sure). Years later I have switched to HP-T/ANARCHY which I'm sure raises rail pressure but evidently at a more controlled rate... 6 months with the new system and narry a code since. My PRV is the same one installed in 2005 when the engine was built.
What causes them to fail? My truck has 120k on it and has been tuned 100% of the time since 40k in 2007 when I bought it from Carmax. While I don't drag race my truck I'm not easy on it by any means. It has seen 135mph, it has seen 4200 rpm but neither very frequently. Based on the evident averages I should be on my 3rd or 4th PRV by now. I am also still using the original injectors which have never been touched. If I could only find a manual transmission that was as durable as my PRV.
All that said has anyone created a PRV that would hold a few thousand more psi? Would a PRV from a late 4th gen be an idea? As I understand it the CP4 runs higher pressure albeit at lower volume to the shagrin of the high performance world. I'm wondering if the cp4 PRV could be adapted to the 5.9/6.7 cp3 engines. Any thoughts?
Blowing solenoids
If you have a pressure relief valve block kit, please remove it, blow on it three times and toss it in the trash can. They were solution to a problem, but the cure is much worse than the disease.
The system needs a valve to relieve huge pressure spikes that occur when the throttle is lifted quickly. The problem is only worse with larger injectors.
FCA duty cycle is higher with larger injectors to keep the target pressure where commanded. Dual pumps, modified puumps, etc all add to the problem, but are not needed to destroy the injectors when no valve is used.
We have seen solenoids exploded off the top of the injectors, nozzles blown apart, cracked injectors, etc. Nearly all this is attributed to the valves being removed from a system that can spike pressures past 60,000 PSI.
We have purchased a "bursting module" with pressure capabilities past 4000 bar ( 58,000 psi ) to do research and development on high pressure common rail fuel components. We can fail parts here at will.
Put em back in or buy injectors, nozzles and parts constantly.
jony360
Jan 13, 2015 04:55 PM
dodgediesel
Nov 25, 2010 07:40 PM
Marcelo Justino
Sep 8, 2007 11:01 AM
snakefarmer
Jan 3, 2006 05:29 PM
