pump removal
pump removal
Has anyone got a good how to set of directions on pulling the cp3. I'm taking mine off this weekend and don't want to run into any suprises. It is pretty straight forward isn't it?
Thanks
Evan
Thanks
Evan
CAUTION: Cleanliness cannot be overemphasized when handling or replacing diesel fuel system components. This especially includes the fuel injectors, high-pressure fuel lines and fuel injection pump. Very tight tolerances are used with these parts. Dirt contamination could cause rapid part wear and possible plugging of fuel injector nozzle tip holes. This in turn could lead to possible engine misfire. Always wash/clean any fuel system component thoroughly before disassembly and then air dry. Cap or cover any open part after disassembly. Before assembly, examine each part for dirt, grease or other contaminants and clean if necessary. When installing new parts, lubricate them with clean engine oil or clean diesel fuel only.
- Disconnect both negative battery cables at both batteries. Cover and isolate ends of both cables.
- Remove intake manifold air intake tube (above injection pump) and its rubber connector hose (2).
- Remove accessory drive belt.
- Thoroughly clean the rear of injection pump, and attachment points for its 3 fuel lines. Also clean the opposite ends of these same 3 lines at their attachment points.
- Disconnect Fuel Control Actuator (FCA) electrical connector (3) at rear of injection pump. CAUTION: Whenever a fuel line fitting is connected to a secondary fitting, always use a back-up wrench on the secondary fitting. Do not allow the secondary fitting to rotate.
- Remove fuel line (injection pump-to-fuel pressure limiting valve).
- Remove fuel line (injection pump-to-fuel rail). Use back-up wrench on fitting at fuel pump.
- Remove fuel line (injection pump-to fuel filter housing).
- Remove fuel pump drive gear access cover with a 3/8 drive ratchet. Access cover (2) is threaded to timing gear cover.
- Remove fuel pump drive gear mounting nut and washer.
- Attach C3428B, or L4407A (or equivalent) gear puller (1) to pump drive gear with 2 bolts, and separate gear from pump (a keyway is not used on this particular injection pump). Leave drive gear hanging loose within timing gear cover.
- Remove 3 injection pump mounting nuts (6), and remove pump from engine.
HUNTINNUT
Jul 27, 2013 11:40 AM
trik396
Jun 1, 2008 07:04 PM
trik396
26
Aug 11, 2006 08:31 PM
