problem w/ quadzilla box and emissions light
Does the truck act funny at all? Check the pins on the connector and make sure none of them look loose or like they might not have a good connection. This shouldn't be the problem, but I hate to leave the easy stuff untouched. There are also some trucks that you can plug the fuel sensor plug into backwards. I have no idea why this is and the truck should run horribly bad, but that may be something to check as well. I doubt that is it as the trucks should barely idle.
I may need to send you a new module to see if it will set the same code?? 0148 is something that is not very common to see.
Quad
Quad
In all actuality the truck runs like a bear! No bucking, sputtering, jerking etc. She runs great! I checked all connections from the get go the first time I saw the light. Everything is firmly fastened down and properly hooked up.
sevobuck
Dec 18, 2011 09:48 AM
Joey-D
Dec 12, 2011 12:52 PM
Smokin98.5
0
May 29, 2008 05:35 PM
04ctd
Oct 5, 2006 08:27 PM
Batts
35
Apr 12, 2006 04:19 PM
