Problem With Quadzilla
I have been running the Std Module for about 3 months with no problems, when I switched it to the 100 Hp setting I had a CEL with a code of P0251. I have read thru several posts and this seems to be a trend. If I upgrade the fuel delivery system to the FASS will this aleviate the problem? thanks
Originally Posted by Knuckle Head
(Post 1292678)
Originally Posted by 973604x4
(Post 1292684)
call Quadzilla and ask firsthand....or wait for Quad here. they're good people who are easy to talk to. Call and ask for Roark...he probably wants a break from explaining how to install boost foolers! [laugh]
(Post 1292705)
I have spoken to them and they want me to send everything back to them, but I am not so sure it's a problem with the module now, but with the truck, I am thinking the module put to much of a demand on the fuel system and something failed.
P0251 Injection Pump Fuel Valve Feedback researching this on DTR and TDR, sounds like a pressure relief valve... replace the banjo bolt with a regular bolt as a rail cap and clear the code. See if the code comes back. this should be a simple way to test to see if its good or not. someone please correct me if i am wrong. |
(Post 1292749)
pull the quad off and see how it runs. if it runs fine, its the Quad. if not, its the truck.
The 0251 code is the 2nd most pain in the rear code that you can get on these trucks. It can mean bad things and it can mean almost nothing.
Typically this code is set because the desired CP3 pressure does not match with the Fuel Control Actuator (FCA). Here are some things that I have seen cause a 0251 code. Bad FCA Bad Connection at FCA or CP3 Bad Relief Valve Stuck Relief Valve Bad Rail Sensor Bad CP3 Bad Lift Pump Some are a pain and others are not. Most likely you are going to have to send it in for service and let them do some tests. Hope that was of some help? Also don't fret too much, Dodge sees plenty of 0251 codes, they should know how to test it by now! |
Thanks I am taking the truck in Friday, I will post the outcome.
