power pup vs triple dog
I have been searchin for about 45 mins now and I cant find a definative answer. What is the differance in the power pup and triple dog? I know the triple dog can do ford chevy and dodge but what is the differace for 05 dodges?
Thanks for any help. |
You can download updates and shift programs on the fly with the TD.
But the power is the same?
Sorry...haven't used the PP...just the TD. I would GUESS that you could get a little more out of the TD with the updated programming...
You can use the triple dog across different MFG's, ie Dodge, Ford, and Chevy.
Im selling my power pup to get the Triple dog, Bully Dog said i cant get the Crazy Larry for the power pup. thats BS in my book!
The Outlook Monitor won't defuel with the PP either, you have to have a Triple Dog to get the full functionality of the Outlook Monitor - I am assuming that is why they package them together, because you will need them both.
my dealer was implying the TD and PP had different programs, but I would assume that is SOTP, it's hard to imply that BD would go thru the effort to build/test 2 different software programs for the 3 levels on each box. |
in early 05 i purchased the powerpup with the outlook. the outlook defueled when the egts went past my warning level. i sent it back around may for the crazy larry version. it still worked fine and defueled when the egts went past my warning. it would be on 100% and then when egts got to hot it would start chopping fueling by going to 75% then 50% then 25% then 0%. i sent both the outlook and power pup in around january of 06 and got the triple dog with outlook. it cost me 100$ to upgrade from bullydog. you can update the triple dog via bullydogs website. or if you know someone or a bullydog dealer that has the latest greatest version they can e-mail it to you. i know the powerpup outlook will not work with the triple dog, and the tripledog outlook will not work with the power pup. but the original outlook with the powerpup will defuel. i would get the triple dog just because of the updates
I am not in the market for the outlook just the programmer.
Grey, did you notice any power diff in the two programmers or differance in driveability? |
when i got the triple dog i had the new scarry larry, so there wasn't really a comparison
What about the tow and performance settins?
the owners manual with the Outlook i have says it won't. and it only hints at the lack of interoperability between the PP & TD outlooks. my local dealer has to send the new ones back because they sometimes have the old SW version on power up. |
I actually don't care for my TD...not sure why but now I'm wishing I had went with the Banks set-up.
I dont mean to be thick but are those ratings for BOTH the TD and the PP?
And thanks for the info. |
| All times are GMT -5. The time now is 03:36 AM. |
