power pup juice stack??
Old Jul 21, 2006 | 04:18 PM
jb903's Avatar
right now im running the power pup stacked with my juice/att. i always run the juice on 5/5 and i have been running the pup on performance but turned it down to tow. man its too slow now. i just got scared when i hear of dropping and injector. not good. how are these making power, can i run the pup on performance or even extreme? anyone running this stack? thanks alot
Old Jul 21, 2006 | 06:18 PM
bigman's Avatar
I stacked the bddl with the juice/ attitude on my 05. The combo has to much timing, so much you can hear it. Run the bddl on extreme because it adds a little pressure, and run the juice on 1 or 2 and that was better to me than the juice on 3 or 4 and the bddl on performance. I stopped at 4 because of the way it sounded. A much , much better stack is the juice and a pressure only box of no more than 50-60 horse. Makes bookoo power. Good luck!
Old Jul 21, 2006 | 07:34 PM
RamWheelsBy4's Avatar
I agree with bigman, I ran the HOT Juice and BDDL for a week or so waiting on my TST upgrade. Keep the Juice on low levels and use higher BDDL levels for optimum power. It is not a real good combo because of reasons stated. The Juice does not have enough adjustability to be able to find good combo with BDDL.
Old Jul 22, 2006 | 01:06 AM
streetsmoker's Avatar
Mine works well mine works well!!!!!!!!! I seem to be the excetion though and I do live with some downsides. Because the BDPP recalibrates your TPS in extreme and performance it has an on/off type of throttle response. So i mainly use it in Lev1 and crank the Juice as desired. With my mods, that is fine it can run mid 13's tuned that way. Both cranked and she runs consistant high 12's. Very smooth power under WOT!!!
Blackedout1ton
Sep 4, 2008 01:43 AM
BuckeyeRed
Jan 12, 2008 03:03 AM
12valve
Jan 5, 2008 11:06 PM
Bradleysram
Apr 6, 2005 07:10 PM
BigDaddyMC
Mar 24, 2005 11:11 PM
