power loss / no smoke / I needs help please
Old Nov 2, 2008 | 12:00 AM
SuperiorRam's Avatar
Originally Posted by CrashCade
Does it feel like you have stock power?
yes it does but we all like stock power i just don't wan't the idea of stock power floating around in my head
Old Nov 2, 2008 | 12:50 AM
JOESHTRDDSL's Avatar
The 03 trucks had the lift pump on the back of the filter housing on the engine. If the dealer did the in tank pump conversion you should not be drawing fuel through it with the fass. Check and see if the stock lift pump is still on the back of the filter housing. If it is the Edge causing the problem then send it in and they will fix it and get it back to you in no time.
Old Nov 2, 2008 | 01:05 AM
it was recalled and revamped to the intankturd now she draws through the new FASS draw straw to the "fuel seperator" (napa cheapo filter) to the fass to the back of the oem fuel filter (the instructions said to also attach some fuel line to the cp3 and showed a pic of god knows what anyway the fuel line went right to where the old one went
Old Nov 2, 2008 | 05:05 PM
CrashCade's Avatar
Well if you are still running stock power or close it sounds like the edge just bit it. Send it in and let us know what you find out.
Old Nov 2, 2008 | 08:58 PM
I am thinking that is the deal too keep ya posted and thanks again. -Eric
Old Nov 16, 2008 | 10:06 PM
SLEDGE's Avatar
any info on the edge yet? curious on this one. my truck went into limp mode the other day at the end of a long trip, lost all power, egts went down to 900...barely any boost...slowed to a crawl... guess that is limp mode?? had to keep putting in and taking out the bullydog to reflash the computer. that was the only thing that would restore the fuel. never threw any codes either..... wierd. a buddy said it could be the MAP sensor. wont do it unless its loaded and doesnt matter if the bd is in or out.
RHC
Aug 12, 2019 03:32 PM
tntk9
Nov 20, 2012 07:09 PM
cbrxxtreme
24
Jul 17, 2008 03:30 PM
billaweed
19
Aug 31, 2007 02:47 PM
shevygi
Apr 6, 2007 05:32 AM
