Popping out of Exhaust @ high RPM
Old Mar 5, 2009 | 01:05 PM
bigwheels94's Avatar
I'm running TNT with Timing 2, & @ high RPM I get a popping/rappy sound out of the exhaust. RP is good, so I know it isn't that. Truck pulls hard, & runs great, just wondering if my timing is too advanced, or if this is normal.
Old Mar 5, 2009 | 01:46 PM
sallyman1's Avatar
could be. bet a valve is partially carboned up possibly burnt and its not seating properly. before you know it that cylinder will be screwed up.just be careful. it happened to me and it is costing me $15,000
Old Mar 5, 2009 | 01:54 PM
tcr's Avatar
tcr
What happens on Timing #3 or 4? Does it do it with 1,3,5,7,9 or only the higher SWs?
Old Mar 5, 2009 | 02:18 PM
soulezoo's Avatar
DTR 1st Sergeant
Classic timing popping. You can verify by going to default timing, run an even numbered SW and see if it goes away. If it does, you have your answer. Then try timing 4... if no popping still try timing 3. If that works, stop, go no further... run timing 3. If it does pop still go back to 4.
Old Mar 5, 2009 | 04:07 PM
I tryed Timing 3 today, & now I'm having trouble hearing what I heard the other day.My buddy in the passenger seat had the window down when I heard it passing a semi. Anyway, I now know that it only seems to do it when pulling hard T/C locked up about 3000+ rpm's. It sounds more like a raspy exhaust note than popping. I put it back to Timing 2 again, & it didn't seem to change at all. Maybe I was hearing things the other day. Truck runs a lot better on TM 2, than Tm 3. On Tm 3 it smoked a little more, & didn't pull as hard either. Also didn't bring the boost up to where I normally see it on Tm 2. Built a little faster maybe, but top lost about 1-2#.
Old Mar 5, 2009 | 06:25 PM
Alright. I set it to Timing 4, & then 3, & then 2 again, & ran up the same hill all three times from 0-80 mph. Boost was always about the same high on TM2 of 41#, low on TM3 @ 39.6#, & TM4 was @ 40#. EGT was the same too, 1335-1360* , & the higher the timing, the raspier the exhaust sounded. But no "popping" that I could hear with the window rolled down 1/2 way on the pass. side. There ws also a hill to bounce the noise off of, but I still couldn't hear the noise I heard when I passed the semi. I guess I was hearing things. Or it was coming from the semi. I don't know.
Old Mar 5, 2009 | 07:50 PM
Mr Bee's Avatar
How could you hear anything with the window down. You would have to wait until your ears melted/thawed out... Window open in Washington in the winter...Just not right Big Wheels94
Old Mar 5, 2009 | 08:45 PM
Hey, It was in the low 50's today. Tomorrow it will snow again tho.
Donemen
15
May 21, 2008 02:26 PM
kwillis-a
Apr 18, 2007 10:40 PM
cumminsdriver635
Mar 6, 2005 10:54 AM
fishin fever
Feb 22, 2004 08:32 PM
klrmark
Sep 4, 2003 09:37 PM
