P0513 Code Please Help!
Old Aug 2, 2008 | 04:13 PM
rynemurch's Avatar
My ABS light and brake light keep flashing and beep! What is this code and what do I need to do to fix it?
Old Aug 2, 2008 | 04:32 PM
05CTDN8's Avatar
You have an issue with your Sim Key. You need to get your factory anti theft unit looked at.
Old Aug 2, 2008 | 04:38 PM
rynemurch's Avatar
will it hurt anything if I keep driving it untill I can get it in the shop this week?
Old Aug 2, 2008 | 08:42 PM
rynemurch's Avatar
Anybody Know?
Old Aug 3, 2008 | 12:10 PM
Rollin'_Coal's Avatar
Do you have an aftermarket remote starter? Mine throws that code on occasion when its running without the key in the ignition. My truck is an 07 but is almost identical to what my 06 was. It won't hurt anything to drive it. Try doing the three key cycle thing to read the codes and it should clear. Hope that helps.
Old Sep 13, 2008 | 10:42 AM
drillpipe's Avatar
Anyone have any input on this? My truck just started doing the same thing, ABS light and brake light flashing and chime going off. Seems to be somewhat erratic, will go off for a while then suddenly stop for 5 minutes or so then start up again. Hasn't affected driving, just annoying.
Old Sep 13, 2008 | 01:58 PM
06RAM2500's Avatar
GENERAL NETWORK ERROR
KEY NOT PROGRAMMED
INCORRECT KEY
INCORRECT VIN IN ECM OR SKIM
LOSS OF COMMUNICATION BETWEEN ECM AND SKIM
Bout the only thing you can do is unplug the ECM connectors and check for corrosion, and clean if necessary.
Everything else, the dealer will have to check with a Star Scan.
Old Sep 13, 2008 | 02:06 PM
DaveB.inVa's Avatar
Mine did this code for a while but I never had the flashing lights. It will clear itself after some amount of starts (50 I think).
Old Sep 14, 2008 | 06:19 AM
drillpipe's Avatar
Thanks for the replys. I'll check the ecm plugs since I just had them loose a couple weeks ago.
Old Oct 13, 2008 | 08:26 PM
saskpuller's Avatar
This is very common if you have a remote starter installed and the installer didn't isolate the mux wire. Throws a tonne of things loopy.
Old Oct 13, 2008 | 09:44 PM
1slo_MM's Avatar
Mine did this too. brought it to the dealer and they replaced small wire harness in the colum I believe. Hasnt done it since, its over a year now.
AVProPres
May 6, 2011 11:56 PM
REX347
Sep 23, 2008 10:56 PM
ramtd02
Jul 7, 2007 07:50 AM
shane156
May 8, 2007 07:52 AM
dakar
Apr 13, 2005 07:24 PM
