OutLook Monitor & Codes
I've had my OutLook Monitor installed for a few months now but lately the connection doesn't want to stay, making the unit flash and reset as if I was cutting the truck on and off. I took the power line that was held together with a male-female connection and put a butt connector in it's place as this is where the unit draws power from. Everything was going fine until yesterday when my boost started reading a constant 44 psi.
This afternoon I got in the truck and my "Check Engine" light came on. It threw P0237 (Boost Sensor 1 Low Voltage), P0113 (Intake Air Temp Sensor High Voltage), and P0236 (Boost Sensor 1 Performance)
Could this be a fault in my OutLook Monitor since it didn't throw codes until my monitor starting acting up? Or do I need to replace sensors?
What would cause my Outlook to read a constant 44 psi? All of the other functions work properly except this one. I called Bully Dog before I got the DTCs and they just told me to reset it and if that didn't work I would need to send it in to them to repair.
Sorry for the long post, I appreciate any help I can get. Thanks guys
-Steve
-Steve
Mark -
Thanks for the reply. I think I am going to have to send it in. I reset the codes and haven't had anything else come up but I still can't get the boost to read properly. If the truck or the boost sensor was the problem I would think it would throw another code. Appreciate the input
-Steve
-Steve
I had a problem with my monitor a couple of weeks ago.The LCD was beginning to fade out. I called Bullydog and they told me to send it in.I sent it in about two weeks ago(just the monitor) and I received the new one today.I thought all I would have to do is re-connect the monitor and all would be fine.The new monitor plug is held in place with shrink tube so now I have to remove the old harness and install the new harness.I also have the older set-up that doesn't use the OBII connector under the dash.They didn't send me the cable for that.I'm not sure if I can just hook up to my old harness and not use the OBII harness.I need to call the tech people tomorrow and find out.
I must say one thing for Bullydog they sent everything (except the OBII harness)including another pyro.
Bradleysram
Feb 3, 2005 01:13 AM
BUZZB8Z
Jan 24, 2005 05:54 PM
anestech*
26
Nov 15, 2004 01:02 PM
anestech*
Nov 7, 2004 12:18 PM
quantrill88
Oct 4, 2004 11:36 AM
