One last video before I unhook edge juice
Old Feb 24, 2008 | 09:09 PM
John_P's Avatar
sallyman:
I would go back to "square one" if I were you! Take that Edge off, along with any other accessories you have installed (like the "****** Whistler") and then re-check those EGT's before you go any further! You may have other problems you are not aware of. I would not think that the exhaust is causing you any problems though.
Good luck.
John_P
Old Feb 24, 2008 | 09:12 PM
durasnack's Avatar
Originally Posted by jamesbfishin
Maybe it's because I'm only used to a stocker but that motor didn't sound too healthy to me either, kinda like it was luggin and had a dead cylinder or something, but I'm no mechanic...
BINGO! i hear it now.....pull the dang edge off....this is ALWAYS the first step in diagnosis!
Originally Posted by John_P
sallyman:
Good luck.
John_P
We've been telling him this for 2 weeks John
Old Feb 24, 2008 | 10:27 PM
CamperAndy's Avatar
He can't check the EGT's with out the Attitude as he does not have regular gauges.
Old Feb 24, 2008 | 10:30 PM
durasnack's Avatar
go buy one....
either way the Juice is coming off, he's got issues of some kind.
Old Feb 24, 2008 | 11:15 PM
highrpms's Avatar
And he does not listen and just creates new threads on every board around, ALL giving the same advise.
Old Feb 24, 2008 | 11:24 PM
05CTDN8's Avatar
Originally Posted by Pull U 2
x3, however, IF he takes the EDGE off and gets a good EGT and boost gauge we can go from there. Remember this is the same guy with the screwy sticker about his ecm.....It could be an ECM/EDGE issue. Lets not flame the guy, lets hope this is the last thread before he posts "Gauges Installed, all is well" or "engine blew before I could get the EDGE out"
Old Feb 24, 2008 | 11:57 PM
05CTDN8's Avatar
Sorry that wasn't pointed at you, just in general, we all get frusterated over this. I cannot imagine if I didnt have the friends/DTR/knowledge base I have now. When my truck went nuts a few months ago I would have lost it. We'll see what happens here.
Old Feb 24, 2008 | 11:59 PM
Kman9090's Avatar
So if you plug the wastegate and get more boost you get the lower the egst go? 40psi is safe on a stocker. Maybe not good for it but I doubt it will grenade it. SOunds like it is about normal. 1400 with lower boost, then with plenty of boost u have level egts.
Old Feb 25, 2008 | 12:28 AM
highrpms's Avatar
Not flamin', just frustrated. I wanna see him figure it out and get it fixed and enjoy his truck, and I wanna know what the problem is.
X2...........
Old Feb 25, 2008 | 05:52 AM
sallyman1's Avatar
here we go again. READ MY TOPIC LINE! this is the last stage/video before i REMOVE EDGE. edge is coming off and im throwing it away. im serious. i have to get gauges yet. Hooking up a boost gauge will suck because where do i tap a hole? i wanna use bourdon gauge and synflex plastic. i dont wanna use electronic gauge because i wanna rule out my MAP sensor.
Old Feb 25, 2008 | 06:01 AM
homewrecker's Avatar
You can tap the airhorn or you can get a boost bolt from Geno's Garage.All boost gauges come with plastic tubing.Diesel Manor has package deal on gauges.You still better be figuring out why your not making boost.Theres a good chance this is not Edge related.How come you have not called about the ecm sticker?Simple thing to check,only takes a phone call!
Old Feb 25, 2008 | 06:06 AM
CamperAndy's Avatar
There are so many options it is not even funny and you do not need to tap a hole. Buy a boost bolt and it replaces one of the intake manifold bolts. The top of the bolt is drilled with NPT threads and ready for your tubing to be connected. 99% of all boost gauges are mechanical you can find electronic ones but you have to really look for those and they have their own sending unit and do not even think of using the MAP (which by the way is working fine based on your many threads and details of events).
Google ISSPRO or get some Auto Meter gauges, just go to the SHOP DTR link above, I made it easy this is the link to the gauge page - Auto Meter gauges
Old Feb 25, 2008 | 06:49 AM
trik396's Avatar
Sally guy, I along with so many others, have tried to help you... all given you good advice... and you're still at square one. I can't do this anymore.
