New Srd X2 module and minor problem with solution.....
Old Nov 15, 2007 | 07:13 PM
donhov's Avatar
Removed the XZT module today and installed my X2 STd module. All seemed Ok at first but running with Recon gauges both pods started doing strange readings. Tried re-plugging all in again and all was good there but readings were strange still, jumping all over the place. Called Jeraimy and he had me try a few different things but no luck. Called back again and got Roarke and he after describing problem he suggested disconnecting boost connection from Recon. X2 Pod now seemed to work stabilize and work OK, he then suggested checking all grounds, found loose connection on Recon ground wire , tightened all grounds and now all works well. IF INSTALLING RECON & X2 BE SURE AND CHECK AND RE-CHECK GROUND CONNECTIONS. Simple fix for what appeared a major problem
On to a 4 mile review. Harness is excellent quality, module is bigger I'm sure to accomadate the faster/larger processor. USP updating is really simple, you will love that feature when the units are avail retail, power is very smooth much more so than the older series boxes & I really like getting water temp on the control pod, along with boost and easy to change on the fly settings.
Over all don't think you will be sorry when it comes out retail, I'm gonna give it a real trial Sunday running from Tampa to Orlando so will give you the real truth after that. Haven't tried level 4 yet but did download the milleage setting and don't notice anything that seems liek slower/lower power than with the XZT unit on.
Old Nov 15, 2007 | 09:24 PM
shortbed rv's Avatar
Are you a beta tester or were you able to upgrade from the XZT to the standard x2. I would like to upgrade but do not know if Quad is able to make this upgrade at this time.
Old Nov 16, 2007 | 09:33 AM
donhov's Avatar
Beta tester !
Thought that this information might save some of you a few problems though.
Who would have believed that a poor groujnd could cause so much trouble...???
jimbo486
Aug 16, 2010 11:00 PM
motochamp250
Oct 28, 2008 07:22 PM
AlpineRAM
Jan 17, 2008 12:41 PM
Tim9712v
Feb 23, 2007 07:51 AM
ppw350z
Sep 5, 2006 07:27 PM
