Nelson/Donaldson mufflers
Old Nov 8, 2006 | 08:44 PM
turbopilot51's Avatar
I am looking to replace my magnaflow with either a Nelson/Donaldson. The drone while towing is deafening! I am wanting to know how others like/dislike the Nelson. The 41" seems to be a good compromise of sound and performance. Also, where is the best place to purchase one?
Old Nov 8, 2006 | 10:49 PM
Big Bob's Avatar
I can vouge for the 51" Nelson, it works great and still sounds good.
Old Nov 8, 2006 | 11:02 PM
1qckdodge's Avatar
I love mine, no drone no vibration, nothin, its awesome, and it still has a nice throaty sound.
Old Nov 9, 2006 | 07:32 AM
omaharam's Avatar
My dad did the 51"x10" with 5" inlet/outlet with adapters. It flows more than any other option for the Donaldson. It sounds completely stock in the cab and just a slight rumble tone when outside the truck. At idle outside the truck it sounds stock as well.
I like it so well, I am thinking of ripping mine all off and gong that route.
Old Nov 9, 2006 | 09:04 AM
TXDRAM's Avatar
51" Nelson
Same here!
Old Nov 9, 2006 | 09:20 AM
tauberson's Avatar
Great purchase. Sound is good and not obnoxious.
Old Nov 9, 2006 | 10:03 AM
rlhay2's Avatar
Can any muffler shop source the 51" Nelson or is it best to mail order and just have them put it on?
If mail order is the way to go, who's recommended?
Thanks,
Old Nov 9, 2006 | 10:38 AM
tauberson's Avatar
You should be able to get it at any local rig shop. Thats where i got mine and it was cheaper that any internet sources.
Old Nov 9, 2006 | 11:38 AM
omaharam's Avatar
Thanks,
he got it through a local big truck shop a long with the reducers and clamps. Then just measure and cut out the cat and muffler and sliip the big ol' thing in and clamp it down.
Old Nov 9, 2006 | 12:11 PM
stock03's Avatar
What about adding a resonator? Or moving the muffler forward to where a resonator would be? Anyone know if this would eliminate drone/vibration?
I was thinking installing my new muffler right after the down pipe instead of where the original one is.
Old Nov 9, 2006 | 12:32 PM
wagonhauler's Avatar
Your local big rig shop should have one that is where i got mine.
That is what i had before i went to 5 inch. The drone was much less with the nelson that with the 5 inch. when it shifts in to OD at 45-50 the drone while towing will drive you
Old Nov 9, 2006 | 07:55 PM
oldman06's Avatar
I am omaharams dad so you known what we think of how it sounds.
I went to the Donldson web site and looked at flow rates. Then I called Donldson and ask who was a local distribiter for there products. Then called and ordered it. The muffler was $95. I also bought 2 adapers 4’’to5” one piece of 36”( only needed 24”) straight pipe belled on one end and clamps. I spent about $150 total
If you take the cat off where it meets the down pipe and the tail pipe out of the back of the muffler. You can install the straight pipe (aprox. 24”) on down pipe,then the muffler w/adapters and then the tail pipe. I used the one hanger on tail pipe to hold it up. Then bent ½” steel bar to go from the muffler to the rubber hangers and welded the steell bar to the muffler. Muffler number is M100580
Old Nov 9, 2006 | 08:10 PM
rjm022's Avatar
i have the 41" donaldson. sounds like the oem muffler at highway speeds. but around town-it is definately has a deeper, better sound to it.
Old Nov 9, 2006 | 08:14 PM
Big Bob's Avatar
I got my 51" Nelson from Cummins Northwest for $66.00.
Old Nov 9, 2006 | 11:29 PM
morkable's Avatar
Has anyone put one of these on a mbrp system,, the drone is going to kill me, even though I put on a resonator.
Kevin
