Nelson/Donaldson mufflers
If you put in a 51" Nelson is there anything else you gotta do?
It's straight through isn't it? The factory is offset, so will you're tali pipe angle change?
My neighbour just got a job at Cummins, hmmm
Everything will line up fine. You should not have to do anything. Yes, it's straight through. I had a local muffler shop install mine while I watched and inspected.
Are Donaldson and Nelson made by the same manufacturer?
Seems you never heare one name mentioned withour hearing the other name as well.
Is there different part numbers, as in is there more than one 51" by each?
I'll get my neighbour to se what they carry.
Thanks
Thanks
Same here
L8r,.............dogger
yeah I tried the resonator too, and mine is pretty close to the downpipe, didnt work to perfection, still the drone is there. I think I am going to look into the mufflers.
Kevin
Kevin
Yes, there are different versions of the 51". For example, you can get it with 4" I/O or 5" I/O. There is also a 9" diameter 51" and a 10" diameter 51".
msiminoff
Feb 20, 2007 08:47 PM
SylvanLaker
Apr 12, 2006 07:50 PM
CTDinMT
May 18, 2004 03:45 PM
Got it at a local truck shop for $66 out the door...
