Which motor is my friend's 2004?
Look at the build date. Anything 1/04 is an 04.5. The 04 and 04.5 motor are C in the vin. Both can be HO. 305/555 or 325/600. Build date is not wrong unless someone change the motor after purchase.
i'm pretty sure this is true....the info brochure from chrysler stated "H.O. unavailable for CA" for the '04 model....i actually ordered my rig and received it in november '03....
What's a 4.0?
305/555 motors were available in 2003 and 2004. In 2004.5 the 325/600 was available. In order to tell if you have a 325/600 you have to look on the white sticker on the driver's side rocker cover below the black plastic valve cover to see what the advertised HP is. Or, you can look at the engine manufacture date on the inside of the door. Anything after January 1st 2004 is the 325 HP until the 2007.5 came with the 6.7 at 350 HP.
