leveling kit
Old Jan 19, 2011 | 08:59 PM
91oldranchtruck's Avatar
leveling kit
I would like to know what all you need to level a 06 2500. Just don't know where to start. Thanks for all the help.
Old Jan 19, 2011 | 10:45 PM
Backwoods Bumpers's Avatar
Vendor - Former Vendor
I'm assuming its a 4x4? If so, you can get the coil spacers on eBay or other places for around $70 shipped. It's not a difficult install. Most folks find that 2" is about right. Also, it's recommended to get your tires aligned afterwards.
Old Jan 20, 2011 | 12:32 PM
no_6_oh_no's Avatar
Coil springs if you want a decent ride and no problems. Adjustable track bar to center the axle again. Adjustable lower control arms to set the caster so it drives correctly. Upgrade the sway bar links if you have very many miles on it.
Old Jan 20, 2011 | 03:52 PM
jumper's Avatar
500-1000# in the bed
Old Jan 20, 2011 | 09:32 PM
I have see where you should get a adjustable sawy bar and other deal that go on the end I just can't remeber what they are called. I just wanting some ideas Thanks for the help.
Old Jan 21, 2011 | 12:53 AM
Adaminak's Avatar
For nothing more than a little time turning wrenches, you can remove the spacers from the rear leaf pack and level it that way. Truck is much nicer to get into and out of, and it's level without excessive open space in the wheel-wells.
Old Jan 23, 2011 | 09:12 AM
Derek Timm's Avatar
Don't drop the front end before you disconnect the sway bar bushings
That makes the total parts cost of the install go up more than double(DOH)
Old Feb 5, 2011 | 03:05 PM
ZMG006's Avatar
Also looking for a leveling kit... All i want to do is get the front up just a little and keep everything safe. I thought that some of these spacers claim they can be added safely and keep all the stock components working properly.
Old Feb 6, 2011 | 04:45 AM
PowerstrokeThis's Avatar
Been Happy with my Kore leveling kit that comes with new coil springs, bilstein shocks, and sway bar drop blocks
Old Feb 6, 2011 | 02:25 PM
ddszero's Avatar
How much did the Kore kit lift the fount end?
Old Feb 7, 2011 | 05:44 PM
ZMG006's Avatar
So your talking about this leveling kit from Kore - http://www.koreraceshop.com/kore-hp-...08-diesel.aspx
That compared to this leveling kit from daystar are quite a bit diff in price. Obviously your getting springs and shocks with the other package but are they really that much better than stock with these spacers? http://www.4wheelparts.com/Lift-Kits...DAYKC09101CAMO
Old Feb 9, 2011 | 04:28 PM
ZMG006's Avatar
Also what would be the ballpark for a shop to install the Kore kit??? I dont have any of the tools, nor the space.
Old Feb 9, 2011 | 05:43 PM
ZMG006's Avatar
Just called 4wheelparts store close to me and they said 270 for the install and 90 to get it aligned.... Whats yalls thoughts on that? As in price and opinion on 4wheelparts quality. TIA
Old Feb 10, 2011 | 04:48 PM
8Lug_hotrod's Avatar
Kore, Lorenz, or Carli. Wich one is the best for leveling kit?
Ready go.
Old Feb 11, 2011 | 03:09 PM
Jezzhuntin's Avatar
I have the Carli coils, love em. Honestly I would spend the extra $ (which isn't much more) and do coils. you won't be disappointed.
