Let's talk Intercoolers....
Old Sep 20, 2008 | 12:51 PM
omaharam's Avatar
Not to get too far off the subject, but what are your egts running? Seems to me - compare our sigs - that you shouldn't be having any real egt problems.
Old Sep 20, 2008 | 01:02 PM
82NDSNPR's Avatar
i can hit 1600 in a heart beat and cruized around 800egt down the highway i had an htt but it leaked bad so i gave it to a bud and he did something to it and is using it i will be installing my second htt this week as i am going down to pick it up latter in the day i will let u all know what the egt drop is in normal driving
Old Sep 20, 2008 | 07:57 PM
PourinDiesel's Avatar
Originally Posted by Dieselhed
Right. I'm looking for the best deal. I can get the ATS for 250-300 cheaper than the HTT or Spearco. Just curious, as ATS is usually more expensive on their aftermarket products compared to others. Could be wrong but I believe the Banks unit is required to use the "High Ram" and their tubes and boots. I'd rather not do that.
I use the ATS intake arm with my Banks Intercooler. The Banks intake arm was too fat for the PPE Dodge dual fueler (dodge pump) kit.
I just bought a conversion silicone hose from www.intakehoses.com and some clamps and it works great.
Old Sep 21, 2008 | 01:45 AM
Dieselhed's Avatar
Wouldn't say egt's are a problem, but I have seen 13-1400. To me, any heat is bad heat.
I was under the impression (and have heard) you had to use the "high ram" with the Technicooler. That is good news as I have the ATS arm as well. Thanks Pourin'.
Old Sep 21, 2008 | 08:48 AM
dieselfan's Avatar
will a new CAC or intercooloer decrease the egts while cruising? or just WOT?
Old Sep 21, 2008 | 10:43 AM
soulezoo's Avatar
DTR 1st Sergeant
No, you probably won't see any difference while cruising. The stock CAC is not all that bad and as long as you are operating in the design specs of the truck, it is pretty good. Aftermarket CACs are not going to make that much difference until you are putting out some good power... or if you tow heavy for long distances making that much more heat.
For the average guy, the expense of a new CAC is not worth the ROI.
Old Sep 21, 2008 | 12:40 PM
Keyser Soze's Avatar
I'm running a Hellmann intercooler and love it.. Great price to..
Old Sep 21, 2008 | 12:58 PM
dieselfan's Avatar
im trying to lower my hwy speed temps, they can be 850-900.
also i will be installing some 220hp stixs this week. and whats good power? 550+?
thanks
Old Sep 21, 2008 | 03:00 PM
82NDSNPR's Avatar
man with sticks that big u need to be dumping alot of water in that motor and get a htt i get hot as hell and i am running 150hp sticks man hope u got a good fuel system to feed them hungry babys
Old Sep 21, 2008 | 03:15 PM
dieselfan's Avatar
im a 2nd gen, i only see a lil over 1k* WOT. so i think i can handle the 220's.
also i dont have my pump tapped. and i have 1/2" lines all the way to the vp and 20+psi.
Old Sep 21, 2008 | 08:31 PM
soulezoo's Avatar
DTR 1st Sergeant
thanks
There is no magic number I am aware of and I am sure lots of different variables will affect that number as well. Yeah, 550+ is as good a number as any. There will be others that may have differing opinions.
The choice of turbo and the air it is putting out will affect that egt number more than the CAC will at cruise.
Old Sep 21, 2008 | 11:08 PM
dieselfan's Avatar
yeah i figured the turbo part, just trying to go the cheaper route, since my turbo is brand new and id hate to spend half of what it cost to change to a 65mm wheel.
thanks though.
Old Sep 21, 2008 | 11:24 PM
Torque master's Avatar
I have had Both Hellman And Banks Intercooler, Banks on my 04-Dodge Ram-2500, And Joe hellmans, Intercooler on my 05-Dodge Ram-2500.
Only Real reason I up-graded the 05 was because that was the year that Dodge had got the wild hair to install the Plastic unit that year.
I never really noticed any real EGT Control differance from running them, I did have a moded Truck into the 500 rwhp range, I really think for one to really benifit from an Intrercooler as mentioned earlier would be if extreme Towing or more than 650rwhp is in play otherwise spend your money better elsewhere
Old Sep 22, 2008 | 12:01 AM
Dieselhed's Avatar
I agree. Although the truck hasn't seen a dyno yet, I hope to be around 650 or above.
Old Sep 27, 2008 | 08:55 PM
morpheus's Avatar
FWIW, the OEM unit is 93% efficient for taking heat out, but only 63% efficient for pressure drop.
