juice settings??
Old Mar 8, 2006 | 08:36 PM
jb903's Avatar
juice settings??
well i got my juice with attitude, man is this the cats meow, but when im setting the performance settings it doesnt seem to stay. i change low boost fueling and that is the same when i check it again, but when i check the performance level its always back at 1?? also it always shows a number 2 in the right corner. i thought this was to show the performance level, but i kept trying to choose level 3. is this right? thanks alot
Old Mar 9, 2006 | 06:39 AM
RamWheelsBy4's Avatar
Other than the normal recheck all connections, etc. Sounds like you have a bad Attitude or Juice module. The settings should stay where you set them and you should see the power level display number change and stay when you press up or down on main screen. A call to Edge I would think.
Old Mar 9, 2006 | 07:52 AM
Argo's Avatar
you may not have the hot wire and ignition wires set up right. if the constant hot wire is not hooked to the right side then it wont save your settings. when I first turn on my truck in the morning or whenever, the attitude monitor will be at 2 and then it will pull up the memory and go to wherever it was set at, usually about 2-5 seconds.
Old Mar 9, 2006 | 03:31 PM
jb903's Avatar
duuuuhhhhh, you just use the up and down arrow to cahnge the settings. directions didnt say that.... i dont think. got it working like a charm.
Old Mar 9, 2006 | 06:39 PM
Dorkweed's Avatar
Muted User
From: "The Peoples Republic of Illinois".....behind enemy lines
Here's your sign!!!
sallyman1
Jun 27, 2011 10:09 PM
novahauler
Sep 4, 2008 12:46 AM
MB
Apr 5, 2007 04:43 PM
svanni
Sep 6, 2006 05:44 PM
