how to (tone ring mod) ?
Old Oct 13, 2005 | 03:19 PM
Hoss's Avatar
Thats MR Hoss to you buddy!
**POOF**
Did that work??
Old Oct 13, 2005 | 04:05 PM
mikmaze's Avatar
hmmmm might have when you posted but I was in the basement checkin on sump pump..... oh well htere's always another tomorrow just around the clock.
Old Oct 13, 2005 | 04:23 PM
Hoss's Avatar
Hmmmm....well, it worked here in Texas. Hasn't rained a drop all day.
Old Oct 14, 2005 | 08:18 PM
dodgedude361's Avatar
We're getting HAMMERED here on the North East coast.Over 6 inchess in 3 days
Old Oct 14, 2005 | 09:28 PM
glowball's Avatar
That was pretty funny hoss. Made me laugh.
Kris
Old Oct 15, 2005 | 04:14 AM
4x4not's Avatar
Repost, but pics:
OK, the weather finally played nice so I crawled under the truck and spend about 45 minutes doing the mod. For those who requested, here are my before and after pictures of the dowel hole:
The tone ring, right off the truck
The tone ring, bored out on the left hand side about 1/8", using a dremel.
So far I have only driven it about 15 miles but I noticed two things so far: There is DEFINATELY more low end power, and I can make her smoke a lot more now under heavy skinny pedal
100% worth the 45 minutes it took me, and I was working slow.
Old Oct 15, 2005 | 07:01 AM
NC_Mog's Avatar
For those having problems loosening the bolts, here's what I did. Use a 15mm socket with no extension and a rachet or breaker bar. Once on a bolt, use the heel of one hand to repeatedly bump the end of the rachet. Muscling the rachet will just turn the engine over. The bumping action is similar to what an impact wrench does.
Old Oct 15, 2005 | 10:29 AM
Xonid's Avatar
Is this mod the same as turning the distro assemble (gas engines) to change timing? Wouldn't that be so much easier. I'll try to find some time today to do the mod. Thanks everyone for the info.
Old Oct 16, 2005 | 05:52 PM
4x4not's Avatar
No, rotating the distributor on a gas engine changes when the SPARK fires, changing the timing on a diesel changes the injector pulse timing. There is no spark.
Old Dec 9, 2007 | 08:01 AM
Mark Hodowanec's Avatar
To the top - in case my PM did not go thru...
Dodgezilla
129
Nov 18, 2005 11:43 AM
BossHogg
Sep 30, 2005 06:31 PM
Dodgezilla
Sep 30, 2005 12:56 PM
Mark Hodowanec
Sep 29, 2005 09:15 PM
BossHogg
Sep 14, 2005 09:48 AM
