how to (tone ring mod) ?
Old Oct 12, 2005 | 11:59 AM
05dodgezilla's Avatar
well just wandering how its done and the pro's and con's thanks
Old Oct 12, 2005 | 02:05 PM
John Rodriguez's Avatar
Tire Hater
There are about 4 threads currently discussing it. It's a 15 minute job with handtools.
Old Oct 12, 2005 | 02:56 PM
Hoss's Avatar
Thats MR Hoss to you buddy!
Or 30 minutes if your slow like me and can't find your 15mm socket.
Old Oct 12, 2005 | 03:16 PM
powerstrokin03's Avatar
how are you guys keeping the pulley from turning? mine just keeps turning
Old Oct 12, 2005 | 03:33 PM
mikmaze's Avatar
or an hour if ya adjust it backwards right hoss ?
Old Oct 12, 2005 | 03:35 PM
Hoss's Avatar
I wouldn't know about that.
Old Oct 12, 2005 | 03:36 PM
Hoss's Avatar
Mine was easy because I have a manual transmission. With an automatic, you'll probably have to use two different ratchets...one to hold one bolt and one to loosen the other bolts. You might try not loosening the belt until you break the bolts loose too.
Old Oct 12, 2005 | 03:57 PM
sat under it for about half hour tried with and without belt.........
spins and keeps spinning
Old Oct 12, 2005 | 03:58 PM
What would i do when i got down to the last bolt?
Old Oct 12, 2005 | 04:03 PM
what do it do?
Old Oct 12, 2005 | 07:17 PM
Lemay427's Avatar
go to the big topic on camshaft sensor thing...your answers wil be there...you might have to read alot of the pages thoough
Old Oct 12, 2005 | 07:40 PM
mikmaze's Avatar
I think this topic is gettin to the point of interest that it deserves a good going through of threads and putting together a sticky and someone needs to supply pics for it, as it is quick becoming the hot topic with way too many pages/ threads to look through to find out the real deal. any way a "pro at this mod or a few can get together and agree on the important thread/ replies needed t9o make this a guide? Or one dedicated member can do it with quoting replies..... please? definately worth a sticky if it gets done well, with the propper non binding liability clause.....
Old Oct 13, 2005 | 11:51 AM
Breakin Loose's Avatar
I agree, this topic does need a sticky. I think it was DTR member "Superduty" that had some good pictures and description on how this mod is done.
Old Oct 13, 2005 | 02:51 PM
Hoss's Avatar
It's really a pretty simple procedure...especially if you have a manual transmission.
Lay down under the front of your truck and you'll see the damper that the serpentine belt goes around (it is directly behind the fan and towards the bottom of the engine).
1) Loosen the belt
2) Loosen the four bolts
3) Pull the damper off I (don't let it fall on your head)
4) Pull the tone ring off
5) File about 1/16th of an inch off of the counter-clockwise side of the dowel pin slot
6) Put the tone ring back on
7) Put the damper back on
8) Turn the tone ring clockwise as far as it will go while tightening one bolt.
9) Tighten all bolts to 30 ft-lbs + 60 degrees of turn
10) Put belt back on.
10 easy steps. Once you've done it you'll think you were silly for thinking it would be difficult.
Old Oct 13, 2005 | 03:01 PM
mikmaze's Avatar
HOSS U da man ! now could ya make it stop rainin so I can try this and my quad box install?
