How to test tranny probe for commander?
Old Dec 18, 2006 | 01:07 PM
twlunn's Avatar
Well EGT, boost and coolant work, but I don’t have tranny temp. I’m pretty sure it’s enabled in the menu.
So I’m thinking wire/connection point or thermocouple probe.
Now my buddy put the diesel manor line in, then I snaked the probe lead down and over to him. While taking nuts/washers off the probe he dropped them. Said he got everything picked up and proceeded hook up the lead.
Now I haven’t crawled under there to look yet, will do it after work. But looking at the install pic from the brochure it looks like there’s a funky washer on the probe, is that some kind of insulator. If so, maybe he missed it when pciking up the nuts & washers for the probe. I’m thinking maybe since the probe must ground itself since there’s only one wire to it. Also I think he Teflon taped it in. Might this be a problem?
Is there a simple way to test the probe while still installed in the line after driving up to temperature, or yank it, hook the Fluke to it and heat it with a lighter?
If I eliminate the probe as bad, I'll go to the wire next...
TIA, T
Old Dec 18, 2006 | 09:28 PM
rodsram's Avatar
What he asked.
Old Dec 19, 2006 | 05:14 AM
AlCorr's Avatar
twlunn, I just installed the Commander in my truck and I know the funny washer your talking about and I believe you should put that washer on the probe first then the elect. wire then coper washer and nut. As you said, I believe it is a insulate washer so the electrical connection won't be grounded out on the probe, where the body of the probe is grounded.
Old Dec 19, 2006 | 06:27 AM
twlunn's Avatar
Thanks Alcor, it is that way.
I guess when I get alittle time I'm going to check the harness wire with a continuity checker...we shall see.
Nutcase
Mar 13, 2008 12:31 PM
thxman
Apr 29, 2007 11:19 PM
tomd
Dec 12, 2006 10:56 PM
stock03
Nov 9, 2006 11:27 PM
