How much boost?
Old Sep 11, 2006 | 11:24 PM
morkable's Avatar
How much boost?
I am running the super Phat shaft 6280, no head studs or oring in the head. I have it set to run around 40psi while towing. I am thinking about raising it to about 45 for towing,, do you think that would be a problem? How much can I go to before I get into trouble?
Old Sep 12, 2006 | 09:43 AM
dodgezilla04's Avatar
i run mine at 45psi. I just dont do anything fun until the motor is completely warm. I wait and watch the water temp gauge for it to go up to half, then drop down a bit and stabilize; meaning the thermostat has open and is regulating temp. then all parts have expanded and sealing is good. really quick way to blow a head gasket, generate lots of boost on a cold motor. really bad with iron block, aluminum head. ask the dmax and psd boys.
Old Sep 12, 2006 | 10:09 PM
strokethis600's Avatar
i have my sps66 set at 55lbs and so far no trouble. just tighten the studs down a couple of times a year. i wouldnt get studs until I blew my stock gasket.
LooseBoltsRob
31
Nov 16, 2007 02:19 PM
MDMIKE
Jan 18, 2005 10:02 PM
NeedMoPower
Jul 12, 2004 10:04 AM
Cumminsdieselboy
Oct 27, 2003 07:36 AM
Wes C
Dec 24, 2002 12:28 AM
