How to get EGTs Down?
Old Oct 6, 2007 | 05:32 PM
Billm2004's Avatar
Question How to get EGTs Down?
What can i do to reduce EGTs? There are not extremely high, but could come down a little.
Old Oct 6, 2007 | 05:34 PM
Mark1si's Avatar
My guess is a bigger turbo.
Old Oct 6, 2007 | 05:36 PM
omaharam's Avatar
What's high? Are you running the CL tune, cuz otherwise I wouldn't think it'd be that hot. But yes, more air. How much boost are you seeing? A boost fooler might be all you need.
Old Oct 6, 2007 | 05:38 PM
bluechrome's Avatar
Do you still have stock exaust? Maybe water meth but a turbo is the best solution.
Old Oct 6, 2007 | 05:49 PM
Billm2004's Avatar
Yes i have stock exhaust, no cat, No CL but temp gets to about 1100 if i stay floored for a 1/4 mile in my extreme tune.i was thinking maybe a high flow muffler and a boost fooler. Im only seeing about 26 PSI with my extreme tune.
Old Oct 6, 2007 | 05:55 PM
Mark1si's Avatar
1100 thats by no meens is "high" I wish i could keep my egt only at 1100.
tritont's Avatar
dude ! your truck almost needs a coat on with those temps ! That is a great temp to see at the end of the 1/4. Burying the gauge is a common thing for those with built trucks running down the track. I'd see 1500F and more by the end of the quarter. Of course, it's on it's way down once OT kicks in.
You're very safe only seeing 1100F
bluechrome's Avatar
1100 is nothing for a common rail. I've hit 1700 before but 1400 is a fairly safe number. the boost fooler is a great idea. The muff is restrictive as well.
Old Oct 6, 2007 | 05:57 PM
Billm2004's Avatar
cool, i think im gonna do the boost fooler and get a muffler for it. what can a stock turbo handle as far as PSI?
Old Oct 6, 2007 | 06:04 PM
tritont's Avatar
be careful if you plan to race with that stock turbo. It doesn't move a lot of air or exhaust. Sure, you can get some decent times with it but, you're doing it at the risk of damaging your engine. Drive pressures can get pretty high with it. You don't want to see anymore than 40psi out of the stock turbo. That's out of it's efficiency range which would be more around 20 to 30psi. At 40psi, you're probably just blowing hot air and not actually gaining from the boost.
Old Oct 6, 2007 | 06:26 PM
omaharam's Avatar
That's not right. It has been dyno proven that 45psi on the stock turbo makes more power than 35psi and 40psi. I ran my stocker at 42-45psi for 25k miles. You're not going to do any damage to the engine as long as egts stay in check.
Old Oct 6, 2007 | 06:30 PM
tritont's Avatar
show me the money brotha ! At 45psi on a stock turbo, the EGT's are NOT staying in check. Been there done that
Old Oct 6, 2007 | 06:32 PM
Billm2004's Avatar
Thanks alot for all the info, i just bought a boost fooler and ill see what happenes when i get it in there. any idea of HP gains with it with my mods, I have a hts trans ordered and ill probably put in my CL as well after i get my trans in there. Im curious as to WHP with my mods and boost fooler and CL, any guesses?
Old Oct 6, 2007 | 07:20 PM
KMKDiesel's Avatar
With your egts that low it doesnt seem right. Where is you egt probe mounted post turbo or preturbo. If it is after the turbo by the downpipe that is the wrong spot. You need it on the manifold to get proper readings. There was a plce around here that were putting them post turbo what morons.
