homemade intake/cold air intake
can someone help me out, and explain to me/tell me how i can make my 03' stock intake with a K&N drop in filter better and more free flowing or is there a way to turn it into a cold air intake
what I did is cut the muffler back off of my truck. Then I took the 4" part of the exhasut and cut a 6" piece out of it and drilled a hole in it. Then I took the top of my airbox off, cut the piece with the airflow sensor bung off of it and put it on the exhaust piece that I had made. Then I bought a high flow aFe pro dry conical filter and put on that. I also cut the bottom and front off of my lower airbox to make a heat sheild out of it. Over all, it works great and all I actually bought was some high temp silicone and the filter.
do what i did, it costs like 10 for silicone and 60 or so for a filter and later on you can add a torque tube and It'll be just as good as an afe stage 1 with torque tube added to it. and you saved 300 bucks
I bought a 5'' 90 degree exhaust pipe elbow, used the stock 90* rubber elbow and put that metal pipe into it....put an afe filter on it and some paint, drilled the holes for the sensor and was done. Sounds awesome and is every bit as good as an afe and is waaaay cheaper. $30 dollars for the pipe and $68 dollars for the filter and about 30 minutes to make.
That ****** Whistler looks easy enough to construct if you dont mind waiting for the parts that are back ordered or they were. And you can even ditch the 6" amsoil filter and go to an S&B for almost half the price. Mine is on the way from verociousmotorsports.com. I talked to Tom and was great to deal with. Also gona try a new elbow on the turbo to get from 4 to 6 inch and then 6 all the way to the filter. May be a week or so but i will show it off when done.
nice signature BTW
brett
53 willys
378
Jul 1, 2007 10:52 PM
