Homemade 6" Air intake, AKA the "whistler", tech write-up
Old Jun 23, 2007 | 05:26 PM
  #361
53 willys's Avatar
Originally Posted by herb
it was pulling the filter minder down before and after i cleaned it (vacumed it the first cleaning --blew out with compressed air second cleaning). replaced it with the original OEM filter and minder has not pulled down again.
oooo your talking about a stock drop in then right???
Old Jun 23, 2007 | 05:32 PM
  #362
herb's Avatar
yes stock drop in Amsoil filter
Old Jun 28, 2007 | 12:10 PM
  #363
04 SO CA's Avatar
53 ******-
Any progress on the intake shield / box? I received my parts order for stage II upgrade. Also the outerwears pre filter fits great. Really need to be pulling cooler air though.
Thanks a bunch.
Rick.
Old Jun 28, 2007 | 01:28 PM
  #364
53 willys's Avatar
Originally Posted by 04 SO CA
53 ******-
Thanks a bunch.
Rick.
grrrr I had to take the truck in cause my recirculation door broke and it was WAAAAAAY to hot to drive with little to no air out put so I was not able to get any made
I Promise I will make 4 shields this weekend
I will have to check cause all 4 may be spoke for already!!!
Old Jun 29, 2007 | 02:03 PM
  #365
biggator60's Avatar
hey *****, please put me on the list for a shield, just bought the elbow for the stage 2 but im waiting to install when i have all the parts..Thanks
Dave
Old Jun 29, 2007 | 02:51 PM
  #366
HarleyHauler's Avatar
Made mine (stage I) and was wondering if someone could tell me where I can pick up a prefilter.
Awesome design - - thanks 53 ******...
Old Jun 29, 2007 | 02:56 PM
  #367
53 willys's Avatar
this is the pre-filter.....http://www.outerwears.com/proddetail.asp?prod=2128
Old Jun 29, 2007 | 05:09 PM
  #368
Thanks again - I ordered it just now to complete the job!
I am debating about removing the silencer ring - any input on benefits vs. drawbacks?
Old Jun 29, 2007 | 05:14 PM
  #369
53 willys's Avatar
I pull my s-rings.. with a stock airbox I noticed a real small sound difference but not much at all ...the intake made the real change.
it wont hurt if you do and wont hurt if you dont.....so???
BTW my TAG is still in my turbo elbow
Old Jun 29, 2007 | 06:33 PM
  #370
biggator60's Avatar
any pics of what the stage 2 box will look like?
Old Jun 29, 2007 | 06:36 PM
  #371
53 willys's Avatar
I had some a few pages back....but they are a teaser shot so you cant see everything..
Old Jun 29, 2007 | 08:22 PM
  #372
04 SO CA's Avatar
Thanks Mark. Let me know If I'm getting close on the list. I wish I had access to the tools to make one. Maybe... a few extra bucks could bump me up the list? Just kiddin'.
Thanks,
Rick.
Old Jun 29, 2007 | 09:09 PM
  #373
RamMan05's Avatar
i did this mod months ago. just wandering, is this filter a dry filter or does it need oiling. mine needs cleaning and was just wandering and if it needs oiling where can i get the cleaning kit
Old Jun 29, 2007 | 10:58 PM
  #374
53 willys's Avatar
no oil is needed, it is all dry....
blow it out with 10-20 psi shop air(from the inside out) or shop vac from the outside and call it good
Old Jun 30, 2007 | 12:02 AM
  #375
THURENfab.'s Avatar
Originally Posted by Hoss
Mine is 4" diameter from the filter to the turbo. I'm all about smooth air flow. Besides, anything bigger than 4" is just a waste and doesn't accomplish anything (except more turbulence and more noise). The turbo inlet is only a 4" diameter opening. Whether your intake tubing is 4" or 8" you're still only going to get 4 inch's diameter worth of air through the turbo.
Your theory regarding airflow is flawed just a BIT in this case.. You've gotta rate the CFM according to your design, and using 4" the entire run would seem to flow just as good as a larger system, but when you add length and bends you cut the CFM a good amount. If your entire intake was 6" long and had no bends then yeah, a 6" dia 6" long pipe isn't going to flow any more, but tapering down in size is best when a little length and some bends are involved... CFM wise..
Test the CFM of a 12" piece of straight 4" pipe, VS. a 20' long 4" dia pipe with multiple bends.. Drastic flow difference.
