Homemade 6" Air intake, AKA the "whistler", tech write-up
Old Mar 3, 2007 | 11:26 PM
  #166
53 willys's Avatar
Originally Posted by Cruizer
I put my intake on today. It really does whistle! I did not remove the baffles in the lower elbow or remove the silencer ring. How much loader will it be if I gut the pipe and remove the ring? I want all the flow I can get. I don't wna to hear engine drone though.
Cruizer
I would leave the turbo air guide (TAG) it will help smooth out the 5.5" tube to the 4" turbo boot transition IMHO
I doubt you will notice much more sound with it gone....
but I say ditch the S-ring
have fun...
Old Mar 4, 2007 | 07:31 PM
  #167
Rockram's Avatar
Well I built my version of the whistler. I went to a truck wrecking yard and found my pieces. I ended up with a piece that fits from the turbo to a 5" then to a 5" elbow to a 5" plastic elbow into a K&N filter. Removed the s-ring.
Took the wife for a ride and she was hot!!! Told me it was toooooooooo loud.
If you have ever sat at the end of an airport runway heard the turbine windup, your listening to my truck. Wife says to quiet it down. So going to put the s-ring back in and see what happens.
Old Mar 4, 2007 | 10:46 PM
  #168
53 willys's Avatar
I don't think the ring will save you it's still going to be loud!
My wife must have a red neck like me because she loves the whistle
BTW you spelled my name wrong in your sig
Old Mar 5, 2007 | 02:54 PM
  #169
Rockram's Avatar
Originally Posted by BTW you spelled my name wrong in your sig[coffee
Oops my bad, I'll get r fixed.
My wife and I drive semi together and after listening to the turbo whine for 10 hours a day she says she don't want to hear it at home. I put the s-ring back in and she says it's better. I'm in the process of making a heat shiels and am hoping it will quite it down in the cab so as I don't have to go back to stock.
I know you were looking into a way to build a heat shield without welding. I think I might have a solution. I'll get mine built and snap some pics. I'm going to the metal shop later this week. I'll keep you posted.
p.s. I'll update my sig.
Old Mar 5, 2007 | 06:41 PM
  #170
53 willys's Avatar
yeah I understand not wanting to hear turbos whine 24/7
I was playing with a box set-up yesterday and I am beginning to think a shield will work better then a full box...
I am toying with the idea of buying a 6" 90*aluminized elbow and using it to drop the WHOLE filter down into the fender area...when it sits down in the fender it is basically already in a box/enclosure naturally No welding needed...but I am having a hard time finding a cheap elbow that makes it worth while
I will keep y'all posted
makes sure you post up some pics of your shield setup!
Old Mar 5, 2007 | 08:06 PM
  #171
jingweed24's Avatar
Guys. Where is the S-ring? I had the intake off the other day and I did not want to mess something up.
Old Mar 5, 2007 | 08:34 PM
  #172
Luvnacumns's Avatar
Silencer Ring.. In the very front of your turbo.. When you remove your air intake and tubing look into your turbo and you will notice a little ring.. Tug and pull and it's gone...
Shane
Old Mar 6, 2007 | 11:37 AM
  #173
Rockram's Avatar
With the intake off the turbo you will see a black snap ring that is about 1/8" thick inside the mouth of the turbo.
You will need a small flat head screwdriver to remove this. Carefully slip the screwdriver between the snap ring and the outside edge of the turbo.
Pry gently til one tip of the snapring comes out.
Then grab the loose end of the snapring and pull towards the center of the turbo.
Once the snapring is out a beveled piece of metal will fall out. this is the S-ring or sound ring as we are calling it.
I hope this works if so this is what your looking for.
Seen this on another site.
Old Mar 6, 2007 | 04:09 PM
  #174
Farmer Davis's Avatar
Looking for opinions. Is the turbo alot louder with the whistler than an afe intake/torque booster tube? Should sell my afe and build one or stay with what I got? I like to hear that turbo sing.
Old Mar 6, 2007 | 06:36 PM
  #175
Cruizer's Avatar
I don't know if it is louder but it sounds very good! For the price of the AFE I would say this is a better setup.
Old Mar 6, 2007 | 07:12 PM
  #176
Dixie Chopper's Avatar
what he said
Old Mar 6, 2007 | 07:15 PM
  #177
53 willys's Avatar
wait tell you guys see stage II whistler!!!
Old Mar 6, 2007 | 07:34 PM
  #178
jingweed24's Avatar
ROCKRAM
OK so I tried to pry off the snap ring to get the s-ring out and it is in there really tight. I tried the small screwdriver where the snap ring ends and I broke the tip of the screwdriver off. Any other ideas?????
Old Mar 6, 2007 | 08:21 PM
  #179
Try two screwdrivers. One to get an opening started. Then use the other one
to keep prying apart the snap ring. Work your way around the turbo with both screwdrivers, eventually it pops out. Be careful not to damage your turbo or hands. Thats how I did it.
Old Mar 6, 2007 | 10:00 PM
  #180
Rockram's Avatar
I use 1 screwdriver and a small hammer. Maybe an ice pick to get under the ring. It was tough and I worked on it for a little while gave up and then tried again. Success the 2nd time.
Make sure to get the broken tip out of the turbo. You don't want that in the turbo or anywhere else. Good Luck.
