high beams and fog lights
Brite Box with Fog Light Control. Fogzilla just makes the fog lights brighter by using a different bulb and harness.
I'd post a link but I don't want to be too helpful and risk getting another warning, never know what evil things you might find on sites outside of this one. Baker Auto Accessories sells them and they are expensive, but I had a very hard time figuring out how to use relays to make it work with this computer-controlled headlight system.
here ya go bud, there are 3 different products on this page, the brite box, fogzilla, and fogster. you can read up on what exactly they do by clicking the the words.
http://www.genosgarage.com/products.asp?dept=6
hope this helps
hope this helps
I just wired the relays together. Here is a pic from Bubba Ctd. Its really simple all you do is run a wire from the running lights to the fog lights. I also did a high beam in fog light mod and it works great. The only thing that I wish that I could change is when you turn your running lights on the fog lights come on too, so if you turn any lights on you get fog lights.[IMG]
[/IMG]
[/IMG]
