Help...trying to updare Smary
Old Dec 23, 2006 | 01:36 PM
TAG06's Avatar
I can not find smarty software loaded windows xp 2.00
Old Dec 23, 2006 | 01:40 PM
Green04HO's Avatar
Start a new folder in your documents and name it Smarty. Put all downloads that pertain to Smarty in it. Make sure all downloads are un-zipped. Then when you are searching for downloads they will be in your documents folder named smarty.
Old Dec 23, 2006 | 01:46 PM
TAG06's Avatar
thanks will try this
Old Dec 23, 2006 | 01:53 PM
Green04HO's Avatar
Also one last thing...are you sure you installed the driver for the Smarty correctly? And have you run any other downloader? If problems persist you could un-install the driver and hook Smarty back up and find the driver in your newly created Smarty folder.(assuming you save it there)
After I un-zip my downloads I get rid of the zip file so the only files in my Smarty folder are the ones needed to update the Smarty.
Hope this helps
Angelo
Old Dec 23, 2006 | 02:24 PM
rstone's Avatar
I downloaded the cdm 2.00c , smarty usb, and the smarty program for the aftermarket injector with the stock turbo.
Old Dec 23, 2006 | 03:15 PM
Green04HO's Avatar
Have you been able to install the Smarty driver yet? When you plug Smarty into the computer you need to search for the cdm 2.00c and select this as the best driver.Do not let windows choose!
After you are sure driver is correct I will try to help you from there. Maybe try to un-install driver from add-remove programs and install again.
Old Dec 23, 2006 | 04:37 PM
rstone's Avatar
Big thanks to Green04HO for walking me through the step to figure this out.
Old Dec 23, 2006 | 09:33 PM
Gas Sucks's Avatar
I saved the drivers in a file named Smarty, it still says cannot install this hardware
It is in a zip file, do i need software to unzip it
Old Dec 23, 2006 | 10:00 PM
MikeyB's Avatar
Yes, need to unzip the files. If you're running XP the archive program is embedded. Just double click the file and select extract. Running 95/98/NT try Winrar. You can download a trail version from here. http://www.rarlab.com/
MikeyB
Old Dec 23, 2006 | 10:24 PM
crobtex's Avatar
I found the download to be easier and friendlier when I unzipped them to a different folder (Smarty Unzipped).
DPatton
Aug 14, 2008 06:12 PM
mgtbob
May 12, 2008 09:30 PM
oldblu
Apr 5, 2008 11:00 PM
screamin01
Nov 2, 2007 10:31 PM
rharveysr
Nov 22, 2006 03:23 PM
