Head studs, install w/o removing head?
Did you bottom tap yours?
I need to see about getin a long tap, or maybe weld a 1/4" extention on a tap like some have done.
Wow, I just looked on e-bay for head studs. ARP's are $399 w/$15 for shipping. A small block Chevy is $130, a Buick 455 is $139. I amm learning that Diesel mods are a tad pricey. The box of Cummins head studs is probably 3x's as heavy as the gas V8's though.
That is cheap, cheap you better jump on that.
I personally dont recommend not changing the gasket when changing studs. Too much chance for bad to happen IMHO. But I dont think that you need studs with a stock charger. I wouldnt worry about studs til around 50psi. I think that the stock gasket should be good (with headstuds) til around 70psi.
kevin
kevin
leeboy
Dec 22, 2014 09:48 AM
77machomopar
Nov 30, 2009 11:55 PM
12valvetom
Nov 27, 2009 11:37 PM
ScottGregory
14
Oct 31, 2009 07:29 PM
BlackBeast
Dec 30, 2006 07:57 PM
