guys with 6 speed and tst powermax chip....
Old Aug 2, 2004 | 12:12 AM
blackdevil's Avatar
are most of you guys running stock clutch? also what settings do you run it on most of the time? i am trying to get a feeling for how long my clutch will last for with the chip. thanks
Old Aug 2, 2004 | 10:16 AM
banshee's Avatar
With just the TST my stock clutch would slip in 6th gear on level 3/3. With the EZ added to it (on level 4) I could get it to slip on anything over 1/1. Another buddy of mine with a 6 speed has about the same results. Low RPMS and heavy throttle make the slip even worse.
John
Old Aug 2, 2004 | 07:31 PM
mattymac's Avatar
My clutch is still holding good but im pretty easy on it as well. I just put it on the dyno and it made 450.1 HP and 1050 TQ level 8/4 thats the highest settings ive ever used. mainly 5/5 was 377 HP and this or lower is what I run on the street.
Old Aug 3, 2004 | 02:33 PM
BulletMan's Avatar
Is TST a good box for towing? What are safe levels to run if you are stock empty and if your stock towing 11,000 LBS Boat?
Old Aug 3, 2004 | 03:18 PM
BigBlue's Avatar
I'd say any level below 3 is fine to tow with. Just watch the pyro meter.
Old Aug 3, 2004 | 11:11 PM
mattymac's Avatar
Ill second that!
Ive pulled 8000lbs over the passes on 4/4 with my air flow improvements with no problems, well other than the clutch.
thek0rn
Apr 20, 2007 02:31 AM
dodgediesel
54
Mar 17, 2007 08:40 AM
dodgediesel
17
Nov 18, 2006 12:47 AM
Dusty Ratcliff
Jun 8, 2006 11:54 PM
blakedill
Aug 4, 2004 03:38 PM
